can i flash 360 throw my motherboard
  • leeunwin
    • 269
    my pc is a acer aspire t180
    amd athlon 64 x2 3800+
    it has 2 sata connections built into motherboard
    1 of wich is being used by hard drive
    can i use the other sata connection to flash my 360???
    are do i need to buy a dedicated card with sata connections
    this is full spec of pc
  • ezzda1
    • 172
    yes System ChipsetnVidia MCP61S + MCP61P, Known compatible sata chipsets - Team Xecuter
    but you will probably need to move the hdd to the secondary port, the 360 drive has to be on your primary port.
    • leeunwin
      • 269
      ok thanks for reply
      • pomocnik
        • Mar 2010
        • 20
        hmm flashing is so complicated
