JungleFlasher 0.1.74(138S)
  • janobi
    • 1624
    Key Verification - thanks to C4eva
    Routines will validate a key against the attached drive 100%
    Routine added to:
    - DVDkey32 Extract, also as key ver is 100%, 6 dumps no longer necessary
    - LO83info Extract, also as key ver is 100%, 2 dumps no longer necessary
    - Source and Target context menus
    IO port refresh
    Extra checks to determine drive hardware type, as opposed the Inquiry info.
    Key is easily queryied from Samsung and Hitachi pre 78, can grab key, verify and lookup KeyDB.
    Lite-On Barcode uniquely identifies drive, look-Up Barcode in KeyDB and verify
    Fancy icon on the Drive Properites group box and tooltip to display Key and KeyDB info.
    Context menu on Drive Properties to peform KeyDb functions ( load files etc )
    KeyDB
    Now index by Lite-on barcode, barcode will be added at next refresh for rapid Drive ID.
    Added an new field call LastFile, this will point to file last used to update KeyDb.
    Useful if you want to refresh KeyDb with all your Lite-On files.
    This is used on Drive Properties Context Menu, to load an OFW.
    Dummy from KeyDB **New**
    There are 3 parts to this
    - for and identified Lite-On this will use the verified key and grab all other dummy data and build it
    - for un-identified Lite-On, will test ALL keys in KeyDB and return on a successful hit, build dummy as above
    - for non lite-on, will test ALL keys in KeyDB and return on a successful hit.
    USB Com Port Enumeration
    Will properly report device types in Vista and Win 7 - FTD2XX.dll dependancy removed
    JungleFlasher User Guide Updates
    to reflect new features (and removal of un-needed parts with new key verification processes/methods)
    We aim to have this updated as soon as possible, work continues but it has changed a large chunk of the tutorial with lots to be ammended
    MEGAUPLOAD - The leading online storage and file delivery service
  • cunny
    • 4915
    I have been awaiting this now, these routines sound intresting, going to try them out over the weekend if i can get chance.
    • punter987
      • 22
      do you still get banned from xbox live with this or has somebody found a way around it?
      cheers
      • killersla
        • 79
        cheers
        yes you can still get banned what ever kind of fw you have on it.
        • killersla
          • 79
          Routine added to:
          IO port refresh
          KeyDB
          Again c4eva and team jungle have done them selves proud with these new added features. I have been using this version of JF for a couple of weeks now and it is very nice to see the key verified bit gives that bit more confidence when using the program, not that i havent already .
          • keithdaman666
            • 19
            i dont understand what this means : Routines will validate a key against the attached drive 100%
            Routine added to:
            hmm ?
