e68 hard drive fault
  • SAFC_FTM
    • Sep 2009
    • 51
    hi guys,
    just srecently got my 360 working again after 2 years of doing nothing with it.
    when i've plugged my xbox hdd in i get the e68 error.
    now the 360 itself works fine flashed with 1.61 for sammy ms28 but as soon as i plug in hdd it won't boot at all.
    from what i've read one option is to do the latest MS update via a usb flash and this might work.
    my only problem with this is will it affect my flash to the ms28 FW?
    the other thing i was thinking of doing was a full spoof of the drive using HDDHackr as though it was a 20g WD BEVS drive.
    any one got any recommendations on what to do?
    I'm not bothered about any games saves etc that are on the drive so whatever method is easier suits me
    cheers
  • mythicx
    • 41
    The update won't affect the flash on your xbox.
    If you've read somewhere that it may help, give it a try and let us know how it goes. We can then help you from there ^^
    • SAFC_FTM
      • Sep 2009
      • 51
      ok, done the dashboard update and still got the error 68.
      gonna have a look around to try and find another e68 fix before i perform the HDD spoof as i'm not certain of doing this as mine is a seagate original and it seems the spoof only works on WD's
      anyone got any other ideas for e68 fix???
      cheers
      • cunny
        • 4915
        Just had a quick google and found this
        [ame=http://www.youtube.com/watch?v=ZRHcCZZOxrA]YouTube - Xbox 360 Error code E68 Fix ????[/ame]
        Try at own risk tho
        • SAFC_FTM
          • Sep 2009
          • 51
          Try at own risk tho
          stumbled across this aswell, worked a treat!
          i would recommend using a proper jumper though instead of the tin foil the guy uses in the vid!
          • cgscott
            • 3513
            Use a jumper from another hard drive and loop the first 2 pins. This is all that is shown in the video.
            Patience is a virtue.
            • SAFC_FTM
              • Sep 2009
              • 51
              sorry don't quite get you're point?
              all that is shown in the vid is the guy using a piece of tin foil to bridge the 2 pins, this does cure the e68 fault but as suggested using a proper jumper is recommended as the tin foil could easily come loose and cause a short anywhere!
              • cgscott
                • 3513
                My point was use a Jumper and bridge the 2 points. I posted literally minutes after your post. So you probably posted as i was typing my reply to the video.
                • SAFC_FTM
                  • Sep 2009
                  • 51
                  just noticed the timings on the posts
                  great minds think alike i guess!
