What mod is the best to buy
  • martiboy
    • 541
    Ok i want to install a mod chip in my 360. after looking for a few days im unsure of what 1 to buy. Basicly what i want is to know what would suit me best. Also i would like to know once these are installed are they a 1 time fix or do they need updated often. i sometimes play online ( with original games ) will this get me banned or will it need turned of. I dont mind about the cost or the difficluty when installing. Any help would be great thanks
  • djjwdubz
    • 1011
    i am not sure about mod chip but i no flash is the one.
    how old is your xbox 360?
    • martiboy
      • 541
      It says on the back 2007-09-01. Im open to any suggestions about flashing. What tools would i need for the flashing. i have looked on other threads and i think that i have a LiteOn drive unsure about the model unitll i open it. any help would be great thanks.
      • djjwdubz
        • 1011
        i don't no how to flash but there are others on here who do.
        cunny or cgscott and there are others here too.
        sorry no help from me.
        • martiboy
          • 541
          Ok i think i now know what i need. If i have any of this wrong could some one point me in the right direction please.
          xecuter ck3 pro with probe
          Jungleflasher
          LiteOn_iXtreme_LT_v1.1 (think this is the latest 1)
          abgx360
          3rd and 4th Wave Video ISO
          Activate ISO (not sure if i would need this)
          And thats it all i think
          • kris9000
            • Apr 2009
            • 121
            Jungleflasher
            abgx360
            you need the top 3 to flash the xbox, abgx is only needed to verify games before you burn them to help stop you getting banned from xbox live.
            Try here for the connectivity kit with probe
            Xecuter CK3 Lite + CK3 Probe 2 - ModTraders.co.uk
            Jungleflasher and the new firmware can be downloaded from this site.
            You are best following the cunny's guide which is posted on the site. Judging by the date on your xbox it must be a very early liton which are pretty easy to do
            • kris9000
              • Apr 2009
              • 121
              sorry, forgot to add, the bottom 2 you mentioned aren't needed if you put the right firmware on
              • cunny
                • 4915
                You need the CK3 kit to power the drive, tho this can be done from the xbox itslef, (harder to achieve power cycle when flashing)
                Probe V1 needed for liteon 73 stock firmware.
                Probe V2 needed for MRA hack (liteon 83v2 and 93 series, or flashed with LT)
                All other drives can be done without ck3 kit or probes ect.
                Why not see what drive is inside yours and post back?
                If you flash with LT then you wont need the activate disc, this was used on earlier firmware to put the drives in boot x mode
                Have a read here and then post if your still uncertain
                • martiboy
                  • 541
                  http://www.digital-kaos.co.uk/forums...updated-53951/
                  Thank you to kris9000 and cunny.
                  I have now opened my xbox (my bad) Its a benq vad6038
                  hw ver j-da1a4
                  fw ver 64930c
                  So now after looking again. I need the ck3 + jungleflasher + iextrem. No need for the probe. In the video it said that there was other metheds to flash but the ck3 would be a better option. Is there another method since the video or should i just go ahead and get the ck3. Thank you again for all your help.
                  • cunny
                    • 4915
                    Donwload jungleflasher
                    Download IX LT 1.1 for BenQ
                    Download JF Guide, and read the Benq section TWICE
                    If you not got compatable chipset, buy PCI VIA 6421
                    You dont need the CK3, you can do the benq without it, using xbox's power to power the drive
                    • martiboy
                      • 541
                      I tryed connecting it to the pc. But jungleflasher cant find it. I have ordered a VIA 6421 SATA PCI CARD. it should be here in a few days. Thanks for all your help and advice. I will post back with the results when i get the card.
                      • martiboy
                        • 541
                        Thanks to every one for there help. I got my PCI VIA 6421 card today. The flash was successfull.
                        • jfish
                          • 799
                          just to add my question on, I got my XBox last Xmas 2009 - so what is the best method to flash my drive, if it is possible
                          I already have a SATA PCI Card in my PC with the VIA Chipset.
                          all help much appreciated,
                          • cgscott
                            • 3513
                            Check the manufacture date on the back of the xbox. I will be able to tell you what your options are then.
                            Patience is a virtue.
                            • jfish
                              • 799
                              Mfg date is 29-10-2009
