Copied game showing up as a DVD?
  • killersla
    • 79
    #16
    Originally posted by alexdc12
    I burnt a game to dvd and it all went sweet. now im assumin my xbox was flashed when i bought it cos i got it with a shed load of copied games, but when i put this game in it comes up as a DVD and the xbox cant play it? any ideas? im not really too bothered as to take it all apart cos me new one will be here when its released! just wonderin if its somethin ive done wrong? i have read the tutorials on here, i run it thru agbx and all was sweet?
    Just to ask but do the other copied games that come with the xbox work? And do origional games work aswell?
    • netham45
      I've also had good luck with Maxstor discs. They're cheaper, but I do have a higher failure rate, so it evens out basically.
      • cunny
        • 4915
        #18
        Not getting into a media debate here. Lots of media will work, the best are VERB, agreed expensive but the cheaper media will help burn out your laser quicker.
        I have had this on liteon drives esp numerous times
        I still say the best way to check this is to hook the drive to a pc and see what firmware is on the drive, we can take it from there. If looking for patching games, this will only work on certain firmwares, those that are strict WAVE COMPLIANT will REQUIRE the ACTIVATE disc to boot patched video partitions.
        • keithdaman666
          • 19
          #19
          I have my Girlfriends xbox at the momment still with factory settings. Never been online etc.. And no matter what disk you put in it reads as DVD. New drive time :-)
          • alexdc12
            • 76
            #20
            yea they both work?
            • cunny
              • 4915
              #21
              Copy a backup to the PC. Download and run ABGX with these settings
              Ok how to configure ABGX.
              Open ABGX
              Goto options tab. You will want a tick in the following :
              Check/Create .dvd file
              Check Stealth
              Verify if stealth passes
              Check/fix video padding
              Check for anyDVD corruption
              Check For updates
              Check game partitions
              Now goto auto fix
              Choose level 3 and just leave a tick out of adjust ssv1 angle for 359
              Goto misc tab
              Select console region
              On split dvd, choose add if does not exist or is invalid.
              Then goto file and save settings. Check the burnt game/.iso and post back what it finds.
              Also forgot to mention that wave 3 games + SHOULD be SSv2. You can manually patch your games prior to burning.
              Then, compare to 1 your trying to play.
              • alexdc12
                • 76
                #22
                so im copying one of the copied games that works?
                • alexdc12
                  • 76
                  #23
                  comparing the two the only diff i can see if the game i have that works is 2nd wave and the one im trying to burn(red dead redemption) is 3rd or 4th wave.
                  on red dead redemption is says stealth is uncertain but at end says all checks passed. on the one that works it says stealth passed.
                  • alexdc12
                    • 76
                    #24
                    \\//\\//\\//\\// _ |_ _ \ \/ /_ _ _ \\//\\//\\//\\//\\//\\//\\//\\//\\//\\
                    //\\//\\//\\//\\ (_||_)(_|/ /\ \_||_ | | //\\//\\//\\//\\//\\//\\//\\//\\//\\//
                    ------------------------_|------_||_||_|--v1.0.2-------[http://abgx360.net]----
                    Checking for updates to abgx360.dat...
                    Server file abgx360.dat no newer than local file - not retrieving
                    D:\Downloads\Red.Dead.Redemption.XBOX360.RF-TL.[https://www.FilmsBT.com]\Red.Dead.Re...X360.RF-TL.dvd is valid
                    Checking Game
                    ISO: "D:\Downloads\Red.Dead.Redemption.XBOX360.RF-TL.[www.FilmsBT.com]\Red.Dead.Redemption.XBOX360.RF-TL.iso"
                    Size: 7838695424 bytes (SplitVid 3rd or 4th wave)
                    Files in ISO: 10, Folders in ISO: 1
                    Total bytes used: 7192145672 (98.54%)
                    Game appears to have random padding
                    Checking default.xex
                    Original PE Filename: rdr2_xenon_final.exe
                    Original PE Timestamp: 2010/04/21 20:56:18
                    Game Name: Red Dead Redemption
                    Developer: Rockstar San Diego
                    Publisher: Rockstar Games
                    Genre: Action/Adventure
                    Avatar Awards: 9 Avatar Awards
                    01. Gentleman's Attire
                    Play Red Dead Redemption
                    02. Lady's Finery
                    03. Yellow Rockstar Logo T-Shirt
                    04. Yellow Rockstar Logo T-Shirt
                    05. Black on Red RDR Logo T-Shirt
                    06. Black on Red RDR Logo T-Shirt
                    07. Sombrero
                    08. Posse T-shirt
                    09. Posse T-shirt
                    Achievements: 48 Achievements totaling 1000 Gamerscore
                    XEX CRC = 1BA10340
                    XEX Media ID: 92F13B089F4CCCE622394972-2AAB34E2
                    Region Code: 0xFFFFFFFF
                    Region Free!
                    Checking SS
                    Timestamp of Authoring: 2010/04/22 00:00:00
                    Timestamp of Mastering: 2010/04/29 17:10:23
                    SS Version: 2 (trusted)
                    SS CRC = 9D80E793 (RawSS = 3AE12274)
                    SS Media ID: 92F13B089F4CCCE622394972-2AAB34E2 (matches game)
                    SS looks valid
                    Checking DMI
                    Timestamp of Authoring: 2010/04/22 00:00:00 (matches SS)
                    DMI CRC = CD80DCD8
                    DMI Media ID: 92F13B089F4CCCE622394972-2AAB34E2 (matches game)
                    DMI looks valid
                    Checking PFI
                    PFI CRC = 05C6C409
                    PFI matches known data (4th wave - requires iXtreme v1.51 [Hitachi only],
                    v1.6 [using activation disc], v1.61 or later)
                    Video partition found
                    Video is zero padded
                    Video CRC = E2FA3A26 (V0 = E0363F4E, V1 = EAE76B94)
                    Video partition does not match known data (could be corrupt or a new wave not
                    seen before)
                    Stealth status is uncertain
                    Starting Verification
                    Looking for 9D80E7931BA10340.ini in the online verified database
                    Server file 9D80E7931BA10340.ini no newer than local file - not retrieving
                    Using 9D80E7931BA10340.ini (340 bytes)
                    Video CRC matches
                    V0 CRC matches
                    V1 CRC matches
                    PFI CRC matches
                    DMI CRC matches
                    SS CRC matches
                    Xex CRC matches
                    AnyDVD style corruption was not detected
                    Game CRC = 830E4200 (matches)
                    All CRCs match
                    Verification was successful, Stealth passed!
                    Comparing L1 Video on L0 to L1 Video on L1...
                    SplitVid is valid
                    L1 Video is zero padded
                    • acestu
                      • 269
                      #25
                      Dual Layer Drive Needed
                      I dont know if anybody else saw you ask if you need a dual layer drive to burn disks, but yes of course you do m8
                      cheers
                      Acestu
                      If my post Helps, then Please Click the THANKS Button ,as i will do for you.
                      The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
                      • alexdc12
                        • 76
                        #26
                        i checked my drive it does support +r dl
                        • ezzda1
                          • 172
                          #27
                          have you had any successfull burns? or is this the first time you are trying to burn a game?
                          what program are you using to burn them?
                          which file are you burning? .iso or .dvd?
                          you should use imageburn, no need to alter any settings just install it.
                          then right click on the .dvd file and select burn using imageburn, tell it to write at 2x or 4x whatever the slowest speed the disc will write at, the slowest verbs write at is 4x the right hand window of imageburn will tell you the disc properties and what speeds it can be burned at when you insert the disc.
                          if it doesnt work then try a different burner but you most likely need a firmware update.
                          • alexdc12
                            • 76
                            #28
                            i was using a .iso and imgburn i believe it needs a firmware update
                              Did you burn the .dvd file ? If theres not a .dvd file with your iso then create one. Simply go to tools. create dvd file.
                              • ezzda1
                                • 172
                                #30
                                maybe not.
                                the .dvd file tells the burner where to insert the layer break, if you just burn the .iso file it will have the wrong layer break (unless you manualy set it in the burning program's settings) and it will show up in the dash as play dvd.
                                do what I said in the post above it will then be burnt correctly and if it doesnt work it will need a firmware update.
