Nat moderate problem
  • skegsagypsy
    • Aug 2009
    • 1230
    Getting this error on the 360, I've opened ports on router, enabled Nat on router and enabled upnp all to no avail, I am using the pc's lan card bridged to connect wirelessly to my network, any help much appreciated.
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
  • SGTFlipFlop
    • Sep 2009
    • 1002
    I agree Skeg is a gypsy if we are on about the same Scottish Skeg
    I have the same problem as you regarding Nat, My router has 2 firewalls, I can disable 1 but not the other, So I always get moderate Nat, Doesn't matter what I try, Its always the same
    • chroma
      • 1976
      Enable DMZ to the 360's ip.
      He who laughs last thinks slowest.
      • skegsagypsy
        • Aug 2009
        • 1230
        Probably is m8
        As for the xbox what a peice of shoite it is, nothing but trouble, the ps3 works like a charm in the other room, no nonsense, no extra charges, microsoft are cnuts
        • skegsagypsy
          • Aug 2009
          • 1230
          Done that chroma, but when I set the 360s ip to manual I cant connect at all
          Tried again can connect now but still the same nonesense...Nat Moderate
          • cgscott
            • 3513
            Get another router. I had an old router (Maxgate) and no matter what i done it wouldnt work. OPen ports and DMZ etc.
            I nmow aheva Dlink router and all is solved with the Nat issues.
            DLink Cable router ?10 on fleebay.
            Patience is a virtue.
            • cunny
              • 4915
              When ever i have had nat issues, i just enabled UPnP, thats with linksy and dlink.
              Just googled it and found this to try
              • skegsagypsy
                • Aug 2009
                • 1230
                I've followed all of the above and yet the stupid things still the same, this a brand new router I bought 2 weeks ago, my only solution now is to hard wire, given that I have wooden floors throughout the house and the 360 is 2 floors up, thats gonna be messy
                • cunny
                  • 4915
                  Silly as it sounds, have to checked the firmware on the router is upto date? Maybe instal latest dash also on 360
                  • skegsagypsy
                    • Aug 2009
                    • 1230
                    Got both the latst dash and the latest firmware, but thanks for the advice cunny
