help?
  • hoop12
    • Jul 2010
    • 7
    help?
    is the error code 0022 and 0020 fixable? i have 2 xboxs with these error codes. thanks in advance
  • janobi
    • 1624
    0022 GPU Error / GPU Overheating
    As is error 0020 both are the begining of the RROD errors, either send back to MS or if out of warranty try to get them reflowed or reballed. Otherwise try selling as is, or get a kit off ebay to try fixing it yourself.
    • killersla
      • 79
      0022 This error is caused by a bridged/shorting solder joint under the GPU, (H)ANA-chip or in between.It can also be power related though, for example if you are drawing power from one of the regulators that power the GPU and HANA-chip.Can also be a component that is missing or damaged so look for missing parts near the GPU and the HANA chip. In extremely rare cases it might also be related to the lines that lead from HANA to the CPU.
      The chances are however higher that it is the GPU than the HANA chip so you should always first concentrate on the GPU.
      0020
      This error is caused by a bridged solder joint under CPU, GPU or one of the RAM bricks.
      This effect can also be caused by tin whiskers leading to shorts and if the GPU was taken off the mainboard this error will also show up.
      It can also be power related(the CPU/GPU or RAM isnt getting enough power). Can also be a component that is missing or damaged so look for missing and bridged parts near the GPU.
      If the console was jtagged and the resistors and cables are still connected it will show 0020, the parallel port can stay as long as no PC is connected.
      • ezzda1
        • 172
        a reflow or xclamp fix will probably sort the 0020 error, however the 0022 error will probably need reballing.
