Jungle Flasher V0.1.75 beta (152)
Description
JungleFlasher is a Windows GUI program for flashing Xbox 360 DVD drives. 64-bit systems are supported in version 0.1.69 and above. See additional JungleFlasher PDF tutorial for usage.
Tutorial is being worked on to reflect the changes - will be updat
JungleFlasher 0.1.75(152S)
Sammy LT 1.0 support
Benq LT 1.2 support
JungleFlasher 0.1.74(138S)
Key Verification - thanks to C4eva
Routines will validate a key against the attached drive 100%
Routine added to:
- DVDkey32 Extract, also as key ver is 100%, 6 dumps no longer necessary
- LO83info Extract, also as key ver is 100%, 2 dumps no longer necessary
- Source and Target context menus
IO port refresh
Extra checks to determine drive hardware type, as opposed the Inquiry info.
Key is easily queryied from Samsung and Hitachi pre 78, can grab key, verify and lookup KeyDB.
Lite-On Barcode uniquely identifies drive, look-Up Barcode in KeyDB and verify
Fancy icon on the Drive Properites group box and tooltip to display Key and KeyDB info.
Context menu on Drive Properties to peform KeyDb functions ( load files etc )
KeyDB
Now index by Lite-on barcode, barcode will be added at next refresh for rapid Drive ID.
Added an new field call LastFile, this will point to file last used to update KeyDb.
Useful if you want to refresh KeyDb with all your Lite-On files.
This is used on Drive Properties Context Menu, to load an OFW.
Dummy from KeyDB **New**
There are 3 parts to this
- for and identified Lite-On this will use the verified key and grab all other dummy data and build it
- for un-identified Lite-On, will test ALL keys in KeyDB and return on a successful hit, build dummy as above
- for non lite-on, will test ALL keys in KeyDB and return on a successful hit.
USB Com Port Enumeration
Will properly report device types in Vista and Win 7 - FTD2XX.dll dependancy removed
JungleFlasher 0.1.73(108S)
Lite-On, Benq LT ver 1.1 Support.
General Support
Better support for 125% / 120dpi in win 7
Bad DevID trap, Message to disable MRA mod and continue.
Links in IRC browser tab will load to default browser rather than IE
DVDKey32
Reg setting Delay32 adjustable from GUI, right click DVDkey32 button.
This will delay key extract to allow time to position probe.
See ver 0.1.59 nfo.
LO-Erase
ESC to cancel failing intro after LO-Erase
Bad Sammy-Un-Lock Key fix
Will launch automatically on see symptoms... CTRL + SHIFt + F10 still works
Dummy from IX
Trap added to fail if key appears as regular inquiry data 05 80 00 32.......
JungleFlasher 0.1.72(101S)
Benq LT Support.
JungleFlasher 0.1.71(98S)
No Lite-On LT spoofing
No longer says copied ID strings when target is LT
No longer Shows false spoof when LT is "spoofed" with older JF ver
- previous versions are not forward compatible with LT
- they may put spoof in place but LT will ignore it.
Hitachi Support
Bug fix - master checksum now set when auto-spoofing Stock Hitachi
Master Checksum now set when spoofing stock Hitachi in firmtools.
Bug fix - JF no longer crashes when saving encrypted Hitachi.
General Support
IRC tab that calls a Java IRC client in embedded browser window
requires 2 dll's... included
JungleFlasher 0.1.70(85S)
Lite On Support
Auto-Load Lite-Touch firmwares
Calibration data
- spoof copies calibration data if present in source
- dummy from target will place calibration data in dummy v2 at same location
Secret Inquiry
- performed before LO83info to identify 83 v2 and abort sequence
- performed for DVDKey, Lo83info and Dummy from iXtreme and added to dummy v2
to differientiate 83v1 & 83v2
Legacy cross spoofing
- bug fixed, now working, sorry ;(
New key locations
- long suspected 74 f/w's with 0x1a000 and 0x1b000 key sectors,
- both found recently, support added.
Gerneral Support
Explorer contexts fixed for start in JF.
Explorer contexts fixed for Win 7.
Thanks go to Team Xecuter for their generous support to this project.
JungleFlasher 0.1.69(75S)
Firmtool Engine
Finally re-coded firmtool engine correctly
- full support for encrypted lite-on, source and target
- easier support for cross spoofing
Port IO
Using Schtrom's driver portIO driver, which includes 64bit support.
iXtreme 1.61 for lite-on
Will autoload iX 1.61 for Liteon
Hitachi Support
Added new spoofing method for Hitachi. "Auto Spoof", will spoof inquiry and key
on the fly directly from source buffer. Will use existing file or request for
load if empty.
KeyDB Viewer
New keyDB, right click source tab.
JungleFlasher 0.1.66(46)
Lite-On 83850c support
- added full LO83info extract, OpenKey to Dummy.bin
- checks added to LO83info.bin.key load, blank data aborts
- 140F0F1011B5223D79587717FFD9EC3A from bad LO83info extract will be rejected
**** WARNING ****
this uses Seacrest source, many thank....
BUT beware...
use a spare drive to check the key
Lite-On support General
Dump Dummy.bin from lite-On iXtreme file (in target context menu)
Identify Barcode reversal
- to detect and fix and use bad inquiry Barcode info
- extra step to Manual spoofing to avoid bad barcode data
Hitachi Support Updated
Stabilty success message is bypassed in Moddermode.
General items Updated
Foreign Language Support
- German
- Portugueuse
- Italian
- French
- Greek
- Spanish (WIP)
JungleFlasher 0.1.65(27)
KeyDB and Log to Notepad fixed for windows 7 and foreign languages
Lite-On-Erase
- Extra check added, Drive Serial is compared to Target f/w
- a mismatch will cause a warning... Just in case user were
- to hook up a new lite-on and forget to do DVDkey32
MtkFlash32
- Disable related windows drive letters on Intro
- Windows interfers with read-back verify as it thinks drive is
- still present after into. This occured primarily with benq
- running ix > 1.41. The half tray unlock also give windows
- drive letter. On intro, drive list is refreshed, scanned for
- the drive on the current port and disabled if found..
- ix 1.6 83850 support added ( cross spoofing of ix revs NOT supported )
- conversion of [barcode].bin.key to dummy.bin
- Autoload dummy, auto-load ix, spoof ix
- extract of [barcode].bin added, for repair
JungleFlasher 0.1.64(16)
Ctrl + F4 to open iXtreme from firmware folder to Target
Added context menus to Source and target tabs
Source
- open f/w from working folder
- clear source
- update to key data base
Target
- open f/w from .\firmware folder
- clear target
Removed - not allowing blank serial in for Lite-on Dummy.bin
previously if serial was blank the iX file serial was left as is
Warning changed for dummy.bin w/o serial, to mention is possibly ok.
Added spoof support for new lite-on 83850C
JF wil recognise a 83850C dummy.bin and spoof 74850C iX accordingly
Manual spoof support for 83850C support added
(still no confirmation of key extract via DVDkey32 method)
Key Database in Registry
Database will be populated automatically from a dump.
Ctrl + F10 to add/update key database from Source tab info
Ctrl + F12 to launch notepad with key database
Ctrl + F11 to create .csv from key database
Added extra item to explorer context to load as source and add key to db
iX will not autoload to target for this task
can select mutliple f/w files, these will load in turn
Fixed bug in Rev 36 Ram Upload Dump Code
All dumps are rev checked immediately, a failure to identify will abort sequence
dumps from other drives and locked 79's (coming back empty) would proceed to key
check and fail
MTKFlash32
Added warning message Yes/No to Flash Erase Button (default is No!)
Added Esc to abort to flash read within auto reads in moddermode
Bypassed Sammy-Un-Lock warning in ModderMode
JungleFlasher 0.1.62
Release for iX 1.6 0800 for Samsung, Benq and Lite-On...
Windows drive enum changed
successful Classic dump will detect and set correct drive type for pre 78 drives. Inquiry of spoofed
drives would select incorrect version.
DVDKey32 Support Updated
better support for Maximus USB Xtractor - using FTDI api FTD2XX.dll
Improved launch times
JungleFlasher 0.1.60
Release for iX 1.6 for Samsung, Benq and Lite-On... Jf will now target 1.6 files by default
Right Click windows drive list for context to open/close drive tray
Added Support for USB Extractor Switch in Vista, for remote launch of DVDkey32 from probe
JungleFlasher 0.1.59 - cleanup to 0.1.55
Added Support for USB Extractor Switch, for remote launch of DVDkey32 from probe
Added optional delay on dvdkey32... allow time for probe.... delay32 in reg, default is 0, max 20 sec
Added Stop-Disk to Hitachi commands, People were still putting in a disk, a habit from FWTB days, commands would fail and the drive would crash.
Improvements to Ram upload dump, should dump in 1 - 1.5 sec... added timer for the fun of it...
Introducing USmodeB with JungleUSB drivers, for Hitachi
1. JungleUSB drivers allow Hitachi on USB to be seen in Mode-A, mode-B command can be issued
2. at power up, you may need to open/close the drive to allow windows to PnP fully
3. Send USmodeB - JF will enumerate all windows drive letters and find any Hitachi, JF will send mode-b
Added, test for port IO....
JF will scan device tree for PortIO, 4 outcomes are possible
i. port io running aok
ii. port removed
iii. port not installed
iv. port io has an error
Fixed, Ctrl f7 for Drive pororties on PortIO, drives were not being detected
Added donate icon, users complained they conuldn't see.... ;-)
JungleFlasher 0.1.55 - cleanup to 1.51
We have probably added or changed alot more but this is what we could remember.
- Portio will only be enabled with "Via Only" ticked, as it was only added to support Via w/o drivers
- Via card must also report status (Code 39)... no drivers loaded
- Mode Select method removed from Port IO. Mode Select is for USB support, port IO does not support USB.
Modder Mode
- Now stops on bad device ID.
Splash Screen
- Context enable/disable removed from splash ( added as a ctrl key)
Advanced Ctrl F Keys
- Ctrl + F5 key, set modder mode backup directory, clear folder to disable it
- Ctrl + F6 key, hitachi read block size 100 --> 2000 ( 78 and 79 FK models will fail on this )
- Ctrl + F7 key, set working folder in modder mode... clear all tabs and save log
- Ctrl + F8 key, enable "Free Flash" and "Ram Poke" in Hiatachi
- Ctrl + F1 key, enable context menus
- Ctrl + F2 key, disable context menus
Lite-On Dummy.bin Serial Fixer
- Bug, fixer added drive barcode byte swapped to Identify string, fixed.
Sammy flash
- was failing for at least one user.. typo in last cleanup. fixed.
Port Inquiry
- Timeout in port Inquiry for drive properties extended from 200ms to 1s
Lite-On-Erase
- Dead time after l-o-erase extended from 2s to 3s
- dots and timer added for better appearance.
Description
Benq LT 1.2 support
Routine added to:
IO port refresh
KeyDB
General Support
DVDKey32
See ver 0.1.59 nfo.
LO-Erase
Dummy from IX
Benq LT Support.
Hitachi Support
General Support
Lite On Support
Calibration data
Secret Inquiry
New key locations
Gerneral Support
Firmtool Engine
Port IO
Hitachi Support
load if empty.
KeyDB Viewer
**** WARNING ****
BUT beware...
- German
- Portugueuse
- Italian
- French
- Greek
- Spanish (WIP)
Lite-On-Erase
MtkFlash32
Source
- clear source
Target
- clear target
check and fail
MTKFlash32
ii. port removed
Modder Mode
Splash Screen
Sammy flash
Port Inquiry
Lite-On-Erase
