Nero and Clone cd are just two amongst many that will copy a copy for you.
I only use imgburn for burning box360 games, so not sure if it copies the protection. With Clone cd you just put your disc in and press copy
there is no protection on a copy of a 360 disk,
just open imageburn at the wizard screen select create image from disk, tell it where to save it, then run the iso it creates through abgx360, just to check it got the stealth sectors right then burn it as you would a download.
by right clicking on the .dvd file abgx created and selecting burn using imageburn.
