lite-on 74850c not dumping !!!
  • dave11674
    • 2025
    hi guys
    again i have one of these drives in
    it says 74850c on the drive label
    but when i inquiry it its a 74910c
    now this is the second ive had that will not dump
    says that on the sticker and then 910c on the inquiry in JF
    any ideas
    as these are not dumping/flashing for me at all
    i am soldering the 2 jumpers together on the drive board just to be safe
    so i dont have to use my CK3 probe.
    mind you it did the same with the probe. BAD DATA ***
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  • cgscott
    • 3513
    Originally posted by dave11674
    hi guys
    any ideas
    dave
    Use an older version of JF. Also i use a serial cable instead of USB to dump.
    Patience is a virtue.
    • dave11674
      • 2025
      hi mate
      tried an older version, 3 like
      still same
      also i dont have the comms lead
      ive done loads on usb no problems
      EDIT
      sorted it
      i removed the jumper wires
      used probe
      and did it with the drive half open
      all good
      thanks dave
      Tools owned.
      AVDI commander.
      Dashfixer orig.
      Dashfixer clone.
      Fiat km tool.
      Opel km tool.
      Ford KM tool.
      Op--com colne.
      Lexia & PP clone.
