Duplicating Backup Game
  • DAVE466
    • 115
    Hi i'm just wondering whether or not it is to just make a straight copy of a backup game.
    ie, blank disc in 1 drive and backup game in other and doing straight copy disc.
    Or would i still have to rip the backup disc?
    Cheers.
  • cgscott
    • 3513
    Never tried it but im sure its possible. I always rip to image then burn back to disc. ONly takes 10 mins to rip to ISO. I think burning from disc to disc would take a lot longer than the method i mentioned.
    Patience is a virtue.
    • DAVE466
      • 115
      no bother mate what dvd drive do i need for the pc to be able to rip them, easier than the inserting dvd take it out and put blank in trick
      • cgscott
        • 3513
        Dual Layer DVD Drive. Most DVD wroters now are Dual layer.
        Then use IMGburn to rip to ISO and burn back to blank media.
        • kris9000
          • Apr 2009
          • 121
          Cheers.
          As cgscott says (he seems to have an uncanny knack of being right) copy the image with imgburn and then burn the image again, you only need one drive. I would always run the image through abgx360 first to make sure it is as stealthed as possible. Whilst it can't guarantee you wont get banned, its the best we have got.
          • DAVE466
            • 115
            no bother mate will be getting some discs this weekend and giving it a try. So icopy the image with imgburn then put it through abgx360 then burn the image to disc?
            Thanks.
            • daz24c
              • 380
              yes thats right mate.you burn the image again with imgburn
              Thank Me If I Help You
              • DAVE466
                • 115
                I'm guessing imgburn will only work that way when copying a copied game? cos i tried putting an original 360 disc in and using image burn went to read image but it said it couldn't as its copied writed??
                would i have to use wx ripper for original games to backup
                • DAVE466
                  • 115
                  All sorted and sussed out. just out of interest when you are copying an image from pc to disc it says to use the dvd file does this mean i could keep all the dvd files for future use and delete all the iso files?
                  • janobi
                    • 1624
                    You can copy on the fly without problem. I have done this many times.
                    Do not delete the ISO files, as this is the main part of the game.
                    • DAVE466
                      • 115
                      No problem thought as much. i have just attemted my first copy of a backup and it failed at 50% in imgburn any ideas? heres a log of it. I am using Aone plus dual layer at 2.4 speed
                      I 15:53:23 ImgBurn Version 2.5.2.0 started!
                      I 15:53:23 Microsoft Windows 7 Ultimate Edition (6.1, Build 7600)
                      I 15:53:23 Total Physical Memory: 720,184 KB - Available: 217,084 KB
                      I 15:53:23 Initialising SPTI...
                      I 15:53:23 Searching for SCSI / ATAPI devices...
                      I 15:53:23 -> Drive 1 - Info: _NEC DVD_RW ND-3500AG 2.18 (E) (ATA)
                      I 15:53:23 -> Drive 2 - Info: _NEC DVD_RW ND-3520A 1.04 (D) (ATA)
                      I 15:53:23 Found 2 DVD?RWs!
                      I 15:56:54 Operation Started!
                      I 15:56:54 Source File: J:\xbox backup\FORZA MOTORSPORT 3.dvd
                      I 15:56:54 Source File Sectors: 3,827,488 (MODE1/2048)
                      I 15:56:54 Source File Size: 7,838,695,424 bytes
                      I 15:56:54 Source File Volume Identifier: DVD_ROM
                      I 15:56:54 Source File Volume Set Identifier: 356fc000MS UDFBridge
                      I 15:56:54 Source File Application Identifier: CDIMAGE 2.45 (12/06/2000 TM)
                      I 15:56:54 Source File Implementation Identifier: Microsoft CDIMAGE UDF
                      I 15:56:54 Source File File System(s): ISO9660, UDF (1.50)
                      I 15:56:54 Destination Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D) (ATA)
                      I 15:56:54 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 2.4x)
                      I 15:56:54 Destination Media Sectors: 4,173,824
                      I 15:56:54 Write Mode: DVD
                      I 15:56:54 Write Type: DAO
                      I 15:56:54 Write Speed: 2.4x
                      I 15:56:54 Link Size: Auto
                      I 15:56:54 Lock Volume: Yes
                      I 15:56:54 Test Mode: No
                      I 15:56:54 OPC: No
                      I 15:56:54 BURN-Proof: Enabled
                      I 15:56:54 Write Speed Successfully Set! - Effective: 3,324 KB/s (2.4x)
                      I 15:56:54 Book Type Setting: DVD-ROM
                      I 15:56:54 Optimal L0 Data Zone Capacity: 1,913,760
                      I 15:56:54 Optimal L0 Data Zone Method: Copied From Original Disc
                      I 15:57:32 Set L0 Data Zone Capacity Succeeded!
                      I 15:57:34 Filling Buffer... (20 MB)
                      I 15:57:34 Writing LeadIn...
                      I 15:57:36 Writing Session 1 of 1... (1 Track, LBA: 0 - 3827487)
                      I 15:57:36 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3827487)
                      I 15:57:36 Writing Layer 0... (LBA: 0 - 1913759)
                      I 16:16:45 Writing Layer 1... (LBA: 1913760 - 3827487)
                      W 16:16:54 Failed to Write Sectors 1916640 - 1916671 - Reason: No Seek Complete
                      W 16:16:54 Retrying (1 of 20)...
                      W 16:16:54 Retry Failed - Reason: Write Error
                      W 16:16:54 Retrying (2 of 20)...
                      W 16:16:54 Retrying (3 of 20)...
                      W 16:16:54 Retrying (4 of 20)...
                      W 16:16:54 Retrying (5 of 20)...
                      W 16:16:54 Retrying (6 of 20)...
                      W 16:16:54 Retrying (7 of 20)...
                      W 16:16:54 Retrying (8 of 20)...
                      W 16:16:54 Retrying (9 of 20)...
                      W 16:16:54 Retrying (10 of 20)...
                      W 16:16:54 Retrying (11 of 20)...
                      W 16:16:54 Retrying (12 of 20)...
                      W 16:16:54 Retrying (13 of 20)...
                      W 16:16:54 Retrying (14 of 20)...
                      W 16:16:54 Retrying (15 of 20)...
                      W 16:16:54 Retrying (16 of 20)...
                      W 16:16:54 Retrying (17 of 20)...
                      W 16:16:54 Retrying (18 of 20)...
                      W 16:16:54 Retrying (19 of 20)...
                      W 16:16:54 Retrying (20 of 20)...
                      W 16:20:06 Retrying (21)...
                      W 16:20:06 Retry Failed - Reason: Write Error
                      W 16:20:07 Retrying (22)...
                      W 16:20:07 Retry Failed - Reason: Write Error
                      E 16:20:47 Failed to Write Sectors 1916640 - 1916671 - Reason: No Seek Complete
                      I 16:20:47 Synchronising Cache...
                      W 16:20:55 User opted to skip the 'Close Track/Session/Disc' functions.
                      E 16:20:55 Failed to Write Image!
                      I 16:20:55 Exporting Graph Data...
                      I 16:20:55 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_10-OCTOBER-2010_15-56_RICOHJPN-D01-67_2.4x.ibg
                      I 16:20:55 Export Successfully Completed!
                      E 16:20:55 Operation Failed! - Duration: 00:24:00
                      I 16:20:55 Average Write Rate: 2,757 KB/s (2.0x) - Maximum Write Rate: 3,473 KB/s (2.5x)
                      I 16:26:02 Close Request Acknowledged
                      I 16:26:02 Closing Down...
                      I 16:26:03 Shutting down SPTI...
                      I 16:26:03 ImgBurn closed!
                      I 19:50:18 ImgBurn Version 2.5.2.0 started!
                      I 19:50:18 Microsoft Windows 7 Ultimate Edition (6.1, Build 7600)
                      I 19:50:18 Total Physical Memory: 720,184 KB - Available: 293,348 KB
                      I 19:50:18 Initialising SPTI...
                      I 19:50:18 Searching for SCSI / ATAPI devices...
                      I 19:50:18 -> Drive 1 - Info: _NEC DVD_RW ND-3500AG 2.18 (E) (ATA)
                      I 19:50:18 -> Drive 2 - Info: _NEC DVD_RW ND-3520A 1.04 (D) (ATA)
                      I 19:50:18 Found 2 DVD?RWs!
                      I 19:51:54 Operation Started!
                      I 19:51:54 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 19:51:54 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 19:51:54 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 19:51:54 Source Media Size: 14,319,616 bytes
                      I 19:51:54 Source Media Volume Identifier: SEP13011042072
                      I 19:51:54 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 19:51:54 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 19:51:54 Source Media File System(s): ISO9660, UDF (1.02)
                      I 19:51:54 Read Speed (Data/Audio): MAX / 8x
                      I 19:51:54 Destination File: J:\xbox backup\sonic mega collection.iso
                      I 19:51:54 Destination Free Space: 102,474,231,808 Bytes (100,072,492 KB) (97,727 MB) (95 GB)
                      I 19:51:54 Destination File System: NTFS
                      I 19:51:54 File Splitting: Auto
                      I 19:51:58 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 19:51:58 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 19:51:58 Reading Layer 0... (LBA: 0 - 6831)
                      I 19:52:01 Reading Layer 1... (LBA: 6832 - 6991)
                      I 19:52:01 Exporting Graph Data...
                      I 19:52:01 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_19-51_N-A.ibg
                      I 19:52:01 Export Successfully Completed!
                      I 19:52:01 Operation Successfully Completed! - Duration: 00:00:07
                      I 19:52:01 Average Read Rate: 1,997 KB/s (1.4x) - Maximum Read Rate: 3,144 KB/s (2.3x)
                      I 19:53:50 Operation Started!
                      I 19:53:50 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D) (ATA)
                      I 19:53:50 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 19:53:50 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 19:53:50 Source Media Size: 14,319,616 bytes
                      I 19:53:50 Source Media Volume Identifier: SEP13011042072
                      I 19:53:50 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 19:53:50 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 19:53:50 Source Media File System(s): ISO9660, UDF (1.02)
                      I 19:53:50 Read Speed (Data/Audio): MAX / 8x
                      I 19:53:50 Destination File: J:\xbox backup\gta.iso
                      I 19:53:50 Destination Free Space: 102,459,895,808 Bytes (100,058,492 KB) (97,713 MB) (95 GB)
                      I 19:53:50 Destination File System: NTFS
                      I 19:53:50 File Splitting: Auto
                      I 19:53:52 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 19:53:52 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 19:53:52 Reading Layer 0... (LBA: 0 - 6831)
                      I 19:53:58 Reading Layer 1... (LBA: 6832 - 6991)
                      I 19:53:58 Exporting Graph Data...
                      I 19:53:58 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_19-53_N-A.ibg
                      I 19:53:58 Export Successfully Completed!
                      I 19:53:58 Operation Successfully Completed! - Duration: 00:00:07
                      I 19:53:58 Average Read Rate: 1,997 KB/s (1.4x) - Maximum Read Rate: 2,651 KB/s (1.9x)
                      I 19:56:49 Operation Started!
                      I 19:56:49 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 19:56:49 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 19:56:49 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 19:56:49 Source Media Size: 14,319,616 bytes
                      I 19:56:49 Source Media Volume Identifier: SEP13011042072
                      I 19:56:49 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 19:56:49 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 19:56:49 Source Media File System(s): ISO9660, UDF (1.02)
                      I 19:56:49 Read Speed (Data/Audio): MAX / 8x
                      I 19:56:49 Destination File: J:\xbox backup\ssx tricky.iso
                      I 19:56:49 Destination Free Space: 102,445,563,904 Bytes (100,044,496 KB) (97,699 MB) (95 GB)
                      I 19:56:49 Destination File System: NTFS
                      I 19:56:49 File Splitting: Auto
                      I 19:56:51 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 19:56:51 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 19:56:51 Reading Layer 0... (LBA: 0 - 6831)
                      I 19:56:54 Reading Layer 1... (LBA: 6832 - 6991)
                      I 19:56:55 Exporting Graph Data...
                      I 19:56:55 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_19-56_N-A.ibg
                      I 19:56:55 Export Successfully Completed!
                      I 19:56:55 Operation Successfully Completed! - Duration: 00:00:05
                      I 19:56:55 Average Read Rate: 2,796 KB/s (2.0x) - Maximum Read Rate: 2,796 KB/s (2.0x)
                      I 19:58:18 Operation Started!
                      I 19:58:18 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 19:58:18 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 19:58:18 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 19:58:18 Source Media Size: 14,319,616 bytes
                      I 19:58:18 Source Media Volume Identifier: SEP13011042072
                      I 19:58:18 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 19:58:18 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 19:58:18 Source Media File System(s): ISO9660, UDF (1.02)
                      I 19:58:18 Read Speed (Data/Audio): MAX / 8x
                      I 19:58:18 Destination File: J:\xbox backup\pgr2.iso
                      I 19:58:18 Destination Free Space: 102,431,232,000 Bytes (100,030,500 KB) (97,686 MB) (95 GB)
                      I 19:58:18 Destination File System: NTFS
                      I 19:58:18 File Splitting: Auto
                      I 19:58:19 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 19:58:19 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 19:58:19 Reading Layer 0... (LBA: 0 - 6831)
                      I 19:58:23 Reading Layer 1... (LBA: 6832 - 6991)
                      I 19:58:23 Exporting Graph Data...
                      I 19:58:23 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_19-58_N-A.ibg
                      I 19:58:23 Export Successfully Completed!
                      I 19:58:23 Operation Successfully Completed! - Duration: 00:00:05
                      I 19:58:23 Average Read Rate: 2,796 KB/s (2.0x) - Maximum Read Rate: 2,796 KB/s (2.0x)
                      I 19:59:17 Operation Started!
                      I 19:59:17 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 19:59:17 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 19:59:17 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 19:59:17 Source Media Size: 14,319,616 bytes
                      I 19:59:17 Source Media Volume Identifier: SEP13011042072
                      I 19:59:17 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 19:59:17 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 19:59:17 Source Media File System(s): ISO9660, UDF (1.02)
                      I 19:59:17 Read Speed (Data/Audio): MAX / 8x
                      I 19:59:17 Destination File: J:\xbox backup\mojo.iso
                      I 19:59:17 Destination Free Space: 102,416,900,096 Bytes (100,016,504 KB) (97,672 MB) (95 GB)
                      I 19:59:17 Destination File System: NTFS
                      I 19:59:17 File Splitting: Auto
                      I 19:59:18 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 19:59:18 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 19:59:18 Reading Layer 0... (LBA: 0 - 6831)
                      I 19:59:22 Reading Layer 1... (LBA: 6832 - 6991)
                      I 19:59:22 Exporting Graph Data...
                      I 19:59:22 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_19-59_N-A.ibg
                      I 19:59:22 Export Successfully Completed!
                      I 19:59:22 Operation Successfully Completed! - Duration: 00:00:05
                      I 19:59:22 Average Read Rate: 2,796 KB/s (2.0x) - Maximum Read Rate: 2,796 KB/s (2.0x)
                      I 20:00:20 Operation Started!
                      I 20:00:20 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 20:00:20 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 20:00:20 Source Media Sectors: 6,992 (Track Path: OTP - L0: 6,832 - L1: 160)
                      I 20:00:20 Source Media Size: 14,319,616 bytes
                      I 20:00:20 Source Media Volume Identifier: SEP13011042072
                      I 20:00:20 Source Media Application Identifier: Session Offset : 0 VTC Sector Offset: 0
                      I 20:00:20 Source Media Implementation Identifier: Smart Storage, Inc.
                      I 20:00:20 Source Media File System(s): ISO9660, UDF (1.02)
                      I 20:00:20 Read Speed (Data/Audio): MAX / 8x
                      I 20:00:20 Destination File: J:\xbox backup\fifa07.iso
                      I 20:00:20 Destination Free Space: 102,402,568,192 Bytes (100,002,508 KB) (97,658 MB) (95 GB)
                      I 20:00:20 Destination File System: NTFS
                      I 20:00:20 File Splitting: Auto
                      I 20:00:21 Reading Session 1 of 1... (1 Track, LBA: 0 - 6991)
                      I 20:00:21 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 6991)
                      I 20:00:21 Reading Layer 0... (LBA: 0 - 6831)
                      I 20:00:25 Reading Layer 1... (LBA: 6832 - 6991)
                      I 20:00:25 Exporting Graph Data...
                      I 20:00:25 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_20-00_N-A.ibg
                      I 20:00:25 Export Successfully Completed!
                      I 20:00:25 Operation Successfully Completed! - Duration: 00:00:04
                      I 20:00:25 Average Read Rate: 3,496 KB/s (2.5x) - Maximum Read Rate: 3,496 KB/s (2.5x)
                      I 20:02:13 Operation Started!
                      I 20:02:13 Source Device: [1:0:0] _NEC DVD_RW ND-3520A 1.04 (D (ATA)
                      I 20:02:13 Source Media Type: DVD-ROM (Book Type: DVD-ROM)
                      I 20:02:13 Source Media Sectors: 2,724 (Track Path: OTP - L0: 2,160 - L1: 564)
                      I 20:02:13 Source Media Size: 5,578,752 bytes
                      I 20:02:13 Source Media Volume Identifier: XGD2DVD_NTSC
                      I 20:02:13 Source Media Volume Set Identifier: 34672923
                      I 20:02:13 Source Media Implementation Identifier: Sonic Scenarist 3.1
                      I 20:02:13 Source Media File System(s): ISO9660, UDF (1.02)
                      I 20:02:13 Read Speed (Data/Audio): MAX / 8x
                      I 20:02:13 Destination File: J:\XGD2DVD_NTSC.ISO
                      I 20:02:13 Destination Free Space: 102,388,236,288 Bytes (99,988,512 KB) (97,645 MB) (95 GB)
                      I 20:02:13 Destination File System: NTFS
                      I 20:02:13 File Splitting: Auto
                      I 20:02:14 Reading Session 1 of 1... (1 Track, LBA: 0 - 2723)
                      I 20:02:14 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 2723)
                      I 20:02:14 Reading Layer 0... (LBA: 0 - 2159)
                      I 20:02:16 Reading Layer 1... (LBA: 2160 - 2723)
                      I 20:02:16 Exporting Graph Data...
                      I 20:02:16 Graph Data File: C:\Users\Dave\AppData\Roaming\ImgBurn\Graph Data Files\_NEC_DVD_RW_ND-3520A_1.04_09-OCTOBER-2010_20-02_N-A.ibg
                      I 20:02:16 Export Successfully Completed!
                      I 20:02:16 Operation Successfully Completed! - Duration: 00:00:03
                      I 20:02:16 Average Read Rate: 1,816 KB/s (1.3x) - Maximum Read Rate: 1,816 KB/s (1.3x)
                      I 20:13:27 Close Request Acknowledged
                      I 20:13:27 Closing Down...
                      I 20:13:28 Shutting down SPTI...
                      I 20:13:28 ImgBurn closed!
                      I 17:56:04 ImgBurn Version 2.5.2.0 started!
                      I 17:56:04 Microsoft Windows 7 Ultimate Edition (6.1, Build 7600)
                      I 17:56:04 Total Physical Memory: 720,184 KB - Available: 213,924 KB
                      I 17:56:04 Initialising SPTI...
                      I 17:56:05 Searching for SCSI / ATAPI devices...
                      I 17:56:05 -> Drive 1 - Info: _NEC DVD_RW ND-3500AG 2.18 (E) (ATA)
                      I 17:56:05 -> Drive 2 - Info: _NEC DVD_RW ND-3520A 1.04 (D) (ATA)
                      I 17:56:05 Found 2 DVD?RWs!
                      I 17:56:08 Close Request Acknowledged
                      I 17:56:08 Closing Down...
                      I 17:56:09 Shutting down SPTI...
                      I 17:56:09 ImgBurn closed!
                      Cheers.
                      • Nakchee
                        • Jun 2009
                        • 17
                        dunno about the log file m8,but i had problems with cheaper discs too,then i bought Verbatim dual layers.....never looked back,had not one single fail since buying them,they may be more expensive,but they are worth it
                        • janobi
                          • 1624
                          If its failing at the layer break then its either the dics or the burner. What burner you using? Have you tried CloneCD?
                          • DAVE466
                            • 115
                            Hi mate my burner is
                            nec dvd rw nd-3500ag and my other burner is
                            nec dvd rw nd-3520a which i have not tried yet.
                            I have a pack of Aone discs and was trying to use these first then was going to buy som vertabims.
                            I'm just about to try and update my burners and put new firmware on them before i try again.
                            • DAVE466
                              • 115
                              Updated burner firmware and Just tried again and got to 50% again and then flashed up with:
                              I/O error!
                              Device (1:0:0)_nec dvd_rw nd-3520aw 3.07 (E (ata)
                              scsistaus: 0x02
                              interpretation: check condition
                              CDB: 2a 00 00 1d 3e e0 00 00 20 00
                              interpretation: write (10) - sectors: 1916640 -1916671
                              sense area: 70 00 03 00 00 00 00 0a 00 00 00 00 02 00 00 00 00 00
                              interpretation: no seek complete
                              Just borrowed a blank vertabim disc from a friend so gonna try that and see if it gets any further if not i will try using clone cd and will post back my outcome.
                              Cheers for the help so far.
