I have a BenQ VAD6038 connected with an xDrive and used CK3Pro to connect it to the mobo and used JungleFlasher. Here is the JF log:
JungleFlasher 0.1.75 Beta (152)
Session Started Tue Oct 19 21:43:23 2010
This is a 32 bit process running on 2 x 32 bit CPUs
portio32.sys Driver Installed
portio32.sys Driver Started, thanks Schtrom !
Found 5 I/O Ports.
Found 1 Com Ports.
Found 7 windows drives C: D: E: F: G: H: I:
Found 0 CD/DVD drives
Drive is Benq..
Drive is Benq..
Sending Magic Keys to Drive on port 0xF0E0
Done!
Sending Vendor Intro
Requesting Device ID
Manufacturer ID: 0xC2
Device ID: 0x11
Flash Name: MXIC(MX25L2005)
Flash Size: 262144 bytes
Getting Status from port 0xF0E0
Serial flash found with Status 0x73
Reading Bank 0: ................
Reading Bank 1: ................
Reading Bank 2: ................
Reading Bank 3: ................
Benq Dump file saved to BENQ-OFW.bin
Loading firmware from buffer
Inquiry string found
Identify string found
Drive key @ 0xB040 3F525D6F66B26B5401E7B42DB1EA9C08
Firmware Osig: [PBDS VAD6038-64930C ]
Firmware is: Stock
Key added to database
Auto-Loading firmware file C:\Documents and Settings\Angst\My Documents\Downloads\JungleFlasher & iXtreme - 10 July 2010\JungleFlasher v0.1.75 Beta (152)\firmware\ix-ltv1.2-benq.bin
MD5 hash: 26a2add0da187dbf6aebce59fd73a1d2
Genuine iXtreme Benq LT 1.2
Drive key @ 0xE040 77777777777777777777777777777777
Firmware is: iXtreme LT 1.2
Spoofing Target
DVD Key copied to target
ID strings already match
Serial data copied from Source to Target
Loading MTK_Flash source file
Target f/w saved as: Benq_CFW.bin
SPi flash found with Status 0x73
Sending Chip Erase to Port 0xF0E0
Erasing:............
Writing target buffer to flash
Writing Bank 0: ................
Writing Bank 1: ................
Writing Bank 2: ................
Writing Bank 3: ................
Flash Verification Test !
Write verified OK !
Sending Vendor Outro to port 0xF0E0
Drive is Benq..
I attempted to use imgburn on 3 different .dvd files with accompanying .iso files in the same location. None of which did the imgburn log have any errors, and the SPTI driver gave no error message as I disabled that service as a result have having Daemon Tools on my comp. abgx360 gave me all green.
Here is my issue: I cannot play anything with this setup other than an original dvd movie. The drive will not play my original copy of games or my backup copies. I have yet to attempt to use a different brand of dvd+r dl discs as I hear verbatim is the way to go, but I feel as if this may not be the issue. Any help would be appreciated. Thank you all for your hard work putting together the tutorials.
Additionally, I have an LG Dual Layer burner that I just purchased recently with which I was burning the copies. It is the internal GH24 'Super Multi DVD Rewriter 24x' drive, and is labeled in device manager as HL-DT-ST DVDRAM GH24LS50.
Found 5 I/O Ports.
Found 1 Com Ports.
Drive is Benq..
Drive is Benq..
Done!
Device ID: 0x11
Firmware is: Stock
Spoofing Target
Write verified OK !
Drive is Benq..
