Hitachi flash error
  • shilo
    • 50
    Hitachi flash error
    just been flashed with relevant firmware and only plays originals now. when i put a backup into the drive i just get open tray any ideas?
    I AM A MIME MY BODY IS MY TOOL!
    NOW GO AWAY OR I WILL
    TAUNT YOU A 2ND TIME
  • cgscott
    • 3513
    Sounds like it doesnt like the Discs you are using. Lasers on the hitachi's can be weak with some discs as they are quite old drives. Burn another disc and see what happens.
    Patience is a virtue.
    • shilo
      • 50
      i have a spare philips laser could i swap that with hitachi one ?
      • m9g
        • 704
        I had exactly the same prob with my hitachi, I increased the power of the laser, google it as its easy to do, still had same problem. Sorted it by buying verbatim discs and all worked fine. Hitachi's are very fussy, get some verbs i think this will sort you out as you cant really go wrong with flashing the hitachi.
        I know they can be quite cheap online but for a quick fix i shot into currys who sell the verb dual layer.
        Regards
        DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
        • shilo
          • 50
          thanx for all the info lads . i am using verb discs but i have not tweaked the laser yet. i will try that if not i will get another one (laser) off ebay and see if that works.
          • m9g
            • 704
            Scenyx Entertainment Community > Xbox 360 Dvd Pot Calibration Tut V1.0 By Moda
            download the pdf, looks a little complicated but actually once you start taking your drive apart it will all be clear and it is really easy, just need a multimeter, to adjust the resistance i found it easier to turn with my fingers
            • shilo
              • 50
              bought a cheap multimeter today about six quid . tinkered with the pot for about 20 mins got it to read all discs well chuffed.
