how do i get a flashed samsung ms28 in to vendor mode?
  • djjwdubz
    • 1011
    hello
    my old xbox samsung ms28 drive will not go into vendor mode. i have a xbox 360 what has a ms25 drive but, i want to swap it for my old ms28 drive.
    is there away to get it into vendor mode? i have took out the board from the 25 and put it in the 28 drive and flashed it but, games are coming up unreadable.
    so i put the board back in the 28 drive and tried to to flash it. no luck tho. any help please
  • m9g
    • 704
    Did you open tray, turn ck off then shut tray half way then turn ck back on?
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
    • djjwdubz
      • 1011
      I'm using the xbox for power.
      • cunny
        • 4915
        Power up xbox.
        Open tray
        Disconnect power from drive (the white plug)
        Push tray half way in
        Send device intro
        Replace power
        • djjwdubz
          • 1011
          i read the tut. i uninstalled the sata drivers and now its not reading my drive at all. what has happend? i have installed them back too but its still not reading the drive.
          • djjwdubz
            • 1011
            all done now thanks to all!
