games wont load xbox 360
  • robbyonthenet
    • 8
    hi can any one help, my sons 360 wont load games and it says play dvd, or it gets a white scren.
    the 360 is not flashed it will load eventually after removing disc and reinserting,thanks in advance.
  • cgscott
    • 3513
    Sounds like the laser is on its way out on the drive.
    Drive replacement or new laser in existing drive is the way forward.
    Try using a dvd cleaner. The fluid and the disc with brushes on it to clean the laser. This may give you some time till you replace the drive.
    Patience is a virtue.
    • robbyonthenet
      • 8
      thanks il try a lens cleaner, the link 4 youtube has been removed.....
      • janobi
        • 1624
        You either need to do a pot adjustment, or get a new drive. You will still need to dump the original drive to get the key for the new drive.
        • robbyonthenet
          • 8
          what is a pot adjustment?
          • smirnoff_rules
            • 8603
            or get the same drive and just swap the board in the drive if u dont want it chipped
            • m9g
              • 704
              Laser adjustment, need to take drive out and follow these instructions, you'll need a multimeter, It is very simple to do, half hour tops start to finish
              DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
