LT+ For PHAT Drives Only
  • cunny
    • 4915
    Here it is, the fw we all want to get passed AP2.5.
    Remember the ISO's with AP2.5 need patching BEFORE ABGX scan, ensuring check/fix padding and have auto fix to level 3
    Official release of C4E's iXtreme LT+
    - Supports Benq and Liteon Drives (74850, 83850V1, 83850V2, 93450)
    - Optimized PFI code to accommodate AP25 SS data
    - Defeats current AP25 protection
    - Protects console from logging AP25 violation
    - Full disc stealth used by default
    - Waveless booting, disc images are assumed to be correct!
    - Split-Vid used as default
  • martiboy
    • 541
    Downloads are here LTPlus.rar
    LOL we posted at the same time. I will now remove. Well done mate.
    • cunny
      • 4915
      there are 3 posts all with same download links, am off to play fable 3 now
      • samlen27
        • 168
        my benq took lt+ and have no probs now my 83850c says play dvd with same disks,is anyone else having same problem
        • smirnoff_rules
          • 8603
          did u manually load the fw to jungle ? and double check your serial was the same in both boxes
          • cunny
            • 4915
            Key spoofed correctly?
            • samlen27
              • 168
              yes the keys are right and im flashing in dos
              • cigo
                • Nov 2010
                • 4
                hi!
                i have already updated to a new dash because i didn't know about this 2.5 ap whatnot and i downlaoded ac brotherhood- so if i flash my drive now this new LT will bypass it and i will be able to play the game and have a new dash? and if there is a reason for flashing i should just follow video instructions that cunny posted sometime before right?
                obviously, i m a total noob when it comes to this but i love assassin too much and i ll try anything. hope someone'll help. Thanks!
                • smirnoff_rules
                  • 8603
                  Originally posted by cigo
                  hi!
                  wot drive have u got
                  • cunny
                    • 4915
                    Try a differant make of disc
                    • samlen27
                      • 168
                      i would try a different disk but the xbox gets stuck on the white xbox loading up screen and wont go no further with Lt+ on,i must be doing something wrong but dont know what as ive been doing a few for some time
                      • cunny
                        • 4915
                        And what it like with just LT on it?
                        • samlen27
                          • 168
                          yes its fine when i put 1.61 on,also is it true that LT+ can see the spoofed liteon as a benq as i was playing nfs last night with spoofed drive am i looking at a ban now?
                          • scousergaz
                            • 10
                            going to ask a dumb question but here goes, i am assuming u figure which drive you have burn the correct LT+ for it then insert into your xbox and let it update and hay presto any game can be played without being bannned
                            yes - no ?
                            • samlen27
                              • 168
                              no u need to flash your drive with the correct firmware then it will play any game
