ABGX V1.04
  • cunny
    • 4915
    ABGX V1.04
    With the release of C4E?s iXtreme LT+ for LiteOn and BenQ drives with ?anti?-AP2.5 the guys over at abgx360 also released a new version of their software.
    What?s new/fixed:
    * AntiPiracy 2.5 (AP25) replay sector for iXtreme LT+ firmware is checked for when a game has the AP25 system flag in the Xex set or when its media ID matches a list updatable through abgx360.dat (Fable III is the only game so far that uses AP25 but does not have the AP25 system flag set)
    * AP25 replay data is Verified/AutoFixed according to your settings, albeit separately from the normal INI based Verify/AutoFix, so make sure to read the entire abgx360 output
    * Video padding size changed to support the new AP25 replay sector using a variable which is updatable through abgx360.dat in case additional stealth sectors are needed so that the video padding check will not blank them out
    * Removed short explanations of ISO filesizes (unnecessary, hard to keep updated and misleading in terms of SplitVid; just because an ISO has the space for SplitVid doesn?t mean it has valid SplitVid data in that space)
    * gzip compression is now supported when abgx360 downloads certain files
    * miscellaneous small changes
    * Note: The GUI has not been changed and will still display version 1.0.2, don?t worry about it as long as the CLI app displays v1.0.4
    http://abgx360.net/download.html
  • shilo
    • 50
    so there is no need to add the patches now on the executer website to the isos? ABGX V1.04 does that automatically right?
    I AM A MIME MY BODY IS MY TOOL!
    NOW GO AWAY OR I WILL
    TAUNT YOU A 2ND TIME
