wrong Keys
  • braindead
    • 103
    wrong Keys
    Can anyone point me in the right direction
    If I flashed my liton with the wrong keys, would it be still able to play legal games ?
    Also do I need the dummy.bin I think I have the key number written down but not in a dummy.bin file
    Please help pulling hair out
  • cgscott
    • 3513
    You will need to manually enter all the info from the drive if you dont have the dummy.bin. Create dummy.bin.
    There is a manual on here that shows you how to do this.
    Patience is a virtue.
    • braindead
      • 103
      If I have flashed a drive and it failed, and now I cant flash it again because JF doesnt see a flash.
      Is there any other program that will allow me to install a flash back to the drive as JF wont let me?
      Thanks in advance
      • cgscott
        • 3513
        You need to flash through dos. The drive must be bricked. Does it eject? If not again DOS is your only option.
        • cunny
          • 4915
          If the drive does not eject. Select correct port from JF. send a device intro, then power on the drive, it should respond with vendor mode
