Spoofing for New Ap2.5
  • acestu
    • 269
    Hi fellas, i have an old console with a Philips Benq drive in it, now i have just put a new Toshiba Samsung drive in it with the latest firmware and spoofed it, it plays all old backups but AP2.5 discs are unreadable, is there anything i can do about this or is it a case of bying another philips benq drive....
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • janobi
    • 1624
    If you LT+ on it, then it should work. If the original drive sig is samsung then the games should boot fine. Make sure you on LT+ and that you have the latest dashboard, and it should work fine.
    • dmunro2002
      • 40
      why didnt you just buy a replacement benq in first place
      • janobi
        • 1624
        Right just read this again. Your problem is that the console is trying to perform the checks as original drive signature is a benq which supports ap2.5 but samsung drives don't so cannot perform the check. You need to change the drive to a benq with lt+ or it ain't going to boot newer games.
