Lt+ flash gone wrong i think?
  • DAVE466
    • 115
    Hi all i'm in the middle of updating my benq drive from lt to lt+ and it has came up with write write verify failed??
    JungleFlasher 0.1.76 Beta (166)
    Session Started Wed Dec 08 12:05:46 2010
    This is a 32 bit process running on 2 x 32 bit CPUs
    portio32.sys Driver Installed
    portio32.sys Driver Started, thanks Schtrom !
    Found 10 I/O Ports.
    Found 3 Com Ports.
    Found 10 windows drives A: C: D: E: F: G: H: I: J: K:
    Found 3 CD/DVD drives D: E: F:
    Sending Vendor Intro to port 0xEC00
    Status 0x51
    Re-sending Vendor Intro:
    Serial flash found with Status 0x73
    Sending Device ID request to port 0xEC00
    Manufacturer ID: 0xC2
    Device ID: 0x11
    Flash Name: MXIC(MX25L2005)
    Flash Size: 262144 bytes
    Getting Status from port 0xEC00
    Reading Bank 0: ................
    Reading Bank 1: ................
    Reading Bank 2: ................
    Reading Bank 3: ................
    Benq Dump file saved to BENQ-OFW(lt+update).bin
    Loading firmware from buffer
    Inquiry string found
    Identify string found
    Drive key @ 0xE040 1BA361F6FB71C3D8E7641C29FA07C131
    Firmware Osig: [PBDS VAD6038-64930C ]
    Firmware is: iXtreme LT 1.2
    Key database updated
    Auto-Loading firmware file J:\Dave's Docs\computers\xbox\JungleFlasher.0.1.76.Beta\Jung leFlasher v0.1.76 Beta (166)\firmware\LTPlus-benq.bin
    MD5 hash: ef3a351f05699a3ee0ad86d63375725e
    Genuine LT plus v1.0
    Drive key @ 0xE040 77777777777777777777777777777777
    Firmware is: LT-Plus
    Spoofing Target
    DVD Key copied to target
    ID strings already match
    Serial data copied from Source to Target
    Loading MTK_Flash source file
    Target f/w saved as: Benq_CFW(lt+update).bin
    SPi flash found with Status 0x73
    Sending Chip Erase to Port 0xEC00
    Erasing:............
    Writing target buffer to flash
    Writing Bank 0: ................
    Writing Bank 1: ................
    Writing Bank 2: ................
    Writing Bank 3: ................
    Flash Verification Test !
    Write Verify Failed !
  • DAVE466
    • 115
    I have clicked on read and it says it is lt+
    Benq Dump file saved to BENQ-OFW2nd.bin
    I still have my stock and lt firmware .bin files.
    • cgscott
      • 3513
      Dont autoload the .bin. Manually locate it and load it. Then spoof the key over. Then write.
      Should do it no probs.
      Patience is a virtue.
      • DAVE466
        • 115
        Thanks for quick reply, but its only the 2nd time i have done this and the 1st one went great but any chance you could tell me where to go from here.
        Do i right click on the source, load firmware ie the lt+ firmware then click spoof?
        • DAVE466
          • 115
          Right things all gone tits up now. Left it as it was pc decided to cut off now xbox has e65 error. Think i may have stood on my keyboard which maybe why it went off. My pc won't recognise the drive now.
          • DAVE466
            • 115
            All done and sorted now thanks. I sussed it i put my stock firmware.bin file in the source and the lt+ in the target then clicked spoof, and followed guide their after.
            Cheers
            • cgscott
              • 3513
              Good to see you sorted
              • DAVE466
                • 115
                Yes thankyou mate.
                I also have stock liteon drive to flash is that just a straight forward flash using jungleflasher?
                • cgscott
                  • 3513
                  You need a CK kit to flash that. Need to probe the r707 port.
                  Not so simple but the JF quide will show you step by step.
                  • DAVE466
                    • 115
                    Yeah just been looking through the guide. Don't really wanna be cutting/soldering anything so what would be the best but cheap (mid-range) kit to buy that doesn't involve soldering/cutting?
                    • cgscott
                      • 3513
                      What revision of Liteon is it? 7,8,9 series?
                      • DAVE466
                        • 115
                        Not sure mate gonna have to open it up again tomorrow night as i thought i was gonna have to cut/solder so put it back together.
                        • cunny
                          • 4915
                          It is possable to tell from the MFR date on back of the box, but always best to check on the drive itself.
                          73 series drives req probing of R707
                          8v1 (aug 2009 mixes revisions) explioted thro sata
                          8v2 (after aug 2009) require MRA hack
                          9 series drives require MRA hack.
                          All above can be done via the MRA hack, also aug is a mixed month so you could gget a 8 series v1 or v2.
                          • DAVE466
                            • 115
                            05 oct 2009
                            • cgscott
                              • 3513
                              Most probably a 9 series drive then.
