Big Brother Is Watching ?
  • acestu
    • 269
    Hi Fellas,
    I took my flashed xbox that has never been online to my parents this weekend and was playing various games on including ap2.5 as the dash had been updated, anyway i thought what would happen if i plugged the tinternet in, so i did and i tried to connect to xbox live, it said i needed to do an update and would restart immediately after, so off it went but on restart 3 red lights, is this a coincidence or has it rendered my xbox useless because i have a modded drive ?
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • karlpowell
    • 189
    i think the 2 things are not related , just coincidace that this happened , do you get an error message on screen ? E71 anything like that ?
    if you do google the error code and find out what is wrong , allso im sure there is a button press you can do that will roll back the updates ( not including the kernel update)
    karl
    • djjwdubz
      • 1011
      how old is the xbox?
      • acestu
        • 269
        No i dont get an error code just a blank screen it dosent even flicker , the console itself is pretty old though...
        cheers
        Acestu
        • willywilson
          • 89
          you will get 3 lights if the cable is not plugged into the back of the tv properly.
          • acestu
            • 269
            OMG
            Yes I know about the video lead thanks, i have just got it home and stripped it down done a solder reflow and reseated both heatsinks but to no avail, when i switch on i just hear the dvd drive rattle for a couple of seconds and get 1 green light in the middle (non going round the outside) and then after a very long 35 seconds every time i get 3 red lights, i am convinced that the update i received has done this, anybody with any input please post....
            Acestu
            • cgscott
              • 3513
              Nothing to do with the update. The box has just RROD'd when you done it. Try fixing it again. I have done a few in the past some come back first time others have to be tinkered with.
              Sound like it could be going towards E74 error but each box is fixable.
              Think he means when you got RROD hold SYNC button and press EJECT. You will get diffent light flashes. Do it 4 times and search for the code online.
              * All four lights flashing - 0
              * One light flashing - 1
              * Two Lights flashing - 2
              * Three lights flashing - 3
              Patience is a virtue.
              • djjwdubz
                • 1011
                mate, after you fix the xbox how long does it last for? i fixed a 2 red light 2weeks ago and he came back on sunday.
                i fixed a 3 red light and its still going, i done that like b4 cod come out.
                can a 1 or 2 red light be fixed for good or a long time?
                • Canker_Canison
                  • 3905
                  It depends on how warped the board is & if you're going to add more cooling.
                  I've fixed a lot of xbox 360's & most will last 6 months to 1 year without any problems. Mine was fixed 2 years ago & still going strong, but it has been bastardised....
                  There are more pics in my profile if you feel the need to play.
                  Canker
                  [COLOR=Green]
                  • cgscott
                    • 3513
                    All of them can be fixed. If they have been tampered with before sometimes its a different case.
                    But i have found any untampered have been fine.
                    Theres is no indidcation on how long they will last with a proper reflow but the cheap fix has 90% worked for me. Although i have had a few duds.
                    Hit or a miss. I think the E74 has to be one of the easiest to fix.
                    • Canker_Canison
                      • 3905
                      I'll second that. If it's a virgin machine with it's seal intact the odds are a lot higher for a good fix.
                      If it's been fixed, or someone attempted to fix it, then it gets a little more hairy.
                      Canker
                      [COLOR=Green]
