Hi i got a new Xbox 4gb, and i have a Hard drive (WD 2500 Bevt), can i add the Hard Drive without do nothing or i need reformat the hard drive???
thank you
get a xbox 360 slim hard drive case from somewhere like www.dealextreme.com or if you cant wait for delivery from china try ebay then follow the guide it also covers slim version.
if you follow the link to the tutorial as in post 2 ,scroll down just below the bootable usb creator tool picture and there is a link to get the 250gb hard drive security sector you need.
you should use the hddhackr program because it rewrited the firmware of the hd/drive to match an original and puts files where they should be, you will need to do this with a sata connection in your pc,when done you can test it in your xbox without a case on the hard drive but it is more secure if you get one.
