kenect sports game problem
  • mickydibble
    • 2166
    hi chaps burned 2 backups of this on verbs,using iso activate disc looks like its going to load game ie: showing kinect warnings etc as if loading then goes blank for a second with a beep it comes back and says unreadable clean disc with soft cloth etc....i think the firmeware is iextreme 1.51,any ideas
  • djjwdubz
    • 1011
    update it to lt+ then all probz will go away!
    • cgscott
      • 3513
      Sounds as if the lasers on its way out. Is it Ixtreme on Hitachi then its fine for reading all games.
      Patience is a virtue.
      • monks key
        • 24
        Had the same problem last year problem got worse started happening all the time ended up replacing the drive works fine now
        Could also be the drive which you burn the games on?
        • mickydibble
          • 2166
          Nah it's a benq,but other games burn/play fine
          • mickydibble
            • 2166
            Everything works fine with other games burning and playing
            • cunny
              • 4915
              First try updating FW but i cant see that working, sounds to me like the laser on way out (as stated)
              2 Chioces
              Replace laser or drive, BenQ drives are simple enough to read spoof write and can be done from a xbox as power source quite easy, just need a compatable chipset.
              BTW replacemnt drives - ?20 on ebay
              • yizzy
                • 10
                try re downloading it agen gould be a doji iso
                • mickydibble
                  • 2166
                  2 Chioces
                  Ok cheers cunny but,it is fine with other games playing ,,, not a clue how to do them things , but I have the correct sata pci card,and executer thingymajig mmmm but never got round to modding 360's
                  • cunny
                    • 4915
                    BenQ's are 1 of the easiest drives to mod.
                    The tutorials posted will show you how, also the jungleflasher guide.
                    IBut mainly this
                    Connect up drive
                    Load JF
                    Find drive
                    Eject tray half open ( eject drive, power off, push in half way, drive on)
                    Device intro
                    Read
                    Save
                    Spoof
                    Write
                    Outro
                    Test
                    First time, 40 mins tops but follow the JF guide to be best and sure
                    • mickydibble
                      • 2166
                      Looks like I finally might have to have a go at this,but I did notice something in settings of imgburn saying microsoftt ,not at home to check!!! but does that sound normal
                      • cunny
                        • 4915
                        Run image thro ABGX and check all ok
                        Then post a pic of the imgburn thingy, i cant say i have seen that before
                        • mickydibble
                          • 2166
                          Ok m8 will do when at home cheers
