Ok to fit a samsung in 360 on lt fw
  • roryson
    • Mar 2009
    • 694
    Is it ok to use a samsung drive in a 360 with the lt firmware not lt+
    Read it had to be on lt+ was told lt is the latest firmware for a sammy
  • janobi
    • 1624
    There is no LT+ for samsung drives mate. The original samsung drives dont have ap2.5 enabled in them. Therefore they cannot do any ap2.5 checks.
    LT+ is only for drives that can perform the ap2.5 check.
    • acestu
      • 269
      NO
      No is the answer, if you spoof a samsung into an xbox that had an original liteon , benq etc it will look for ap25 sector on the disk..
      You can only get away with the samsung not being able to read ap25 if it is the original stock type drive and not spoofed...
      Hope this helps
      Acestu
      If my post Helps, then Please Click the THANKS Button ,as i will do for you.
      The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
      • djjwdubz
        • 1011
        keep the samsung with its motherboard, use the samsung drive to stay safe. it has lt1.0 thats how good samsung is cuz it never needs updating the flash!
        • janobi
          • 1624
          Hope this helps
          Acestu
          Thats not what he was asking. He was asking if LT is safe to use rather than LT+
          The update of the flash is nothing to do with the samsung being a good drive. Its simply that it cannot do ap2.5 checks, therefore LT+ is not required.
