problems swapping samsung MS25 with MS28
  • roryson
    • Mar 2009
    • 694
    if i buy a 360 with a MS25 drive installed. would there be any problems installing a MS28 drive. i.e getting banned or such things...??? or problems flashing..??
  • djjwdubz
    • 1011
    your safe to do that mate! use the ms28 and do not use the ms25.
    • djjwdubz
      • 1011
      have you ever flashed a xbox befor? samsung is one of the easiest to flash.
      • roryson
        • Mar 2009
        • 694
        ive took notice of djjwdubz and ordered a MS28 to insert when i get my box. but gonna have to flash it. there cheap enough but dont know how to flash it. ill be safe using the MS25 offline till i replace the drive wont i.. i was told that the only difference between the drive if the firmguard. ifso why use the 28 and not the 25..??
        • djjwdubz
          • 1011
          everyone knows of ms28 is safe, ms25 might get banned but if they have no ap25 check then they are good too.
          use ms25 an stay offline or risk it.
          • roryson
            • Mar 2009
            • 694
            just gotta learn how to flash the ms28....
            • djjwdubz
              • 1011
              look at the stickys at the top of the xbox section! its easy to do! you will only need a sata port cuz you can use the xbox to power the drive while the sata lead is plugged into the pc and xbox.
              • roryson
                • Mar 2009
                • 694
                cool, ill look it up. thankx bud...
                • roryson
                  • Mar 2009
                  • 694
                  ordered a flashed box yesterday and my friend told me a bit ago today there's a elite with 5 games going for ?95 in the local paper.. bummer..
                  • djjwdubz
                    • 1011
                    all versions of Samsung do not have AP2.5! just found it mate ms25 is safe to then!
                    • roryson
                      • Mar 2009
                      • 694
                      ha, i have a spare drive then. pitty about the elite init..
                      • djjwdubz
                        • 1011
