For years I i stuck to making games using my old faithfull pionner 111D and it shat itself , so went down to a wee shop in the town, bought a sony AD-7261s thinking it would be a good drive but so far all my games are ~~~~ed either mixed media disc comes up or unreadable disc is displayed , i downloaded imgburn and tried to burn with this too to no avail, any ideas as to what the issue is? p.s im using verbatum discs too btw, thanks
Burning Games Problems
Did you make sure layer break was set correctly if you dont use the .dvd file that is made when using abgx?
Sound like its not burning it correctly which is causing it to display mixed media disk. By not setting layer break 1913760 then you will always get this issue.sigpic
Patience is a virtue.Comment
i was thinking about this earlier, i wasnt using the dvd file just the ISO, sorted. Thank youComment
ok so i have a different problem with my burnt games. they will only work sometimes, more often than not the xbox will read they for a few seconds then ill see an open tray where the play game should be. some times the games work within 2 or three tries but sometimes they don't work at all. i am confused because my other backups work just fine.Comment
so after about 30 mins of opening and closing the tray it finaly red the disk, started up but when i tried to get into a game online it froze and now i cant get it to read. when i check the disk with agbx everything checks out.Comment
