I was looking at this all day on youtube and google and am thinking about doing it as I have a great little Lian li pc -7 tower which would be perfect for it.
Main reason is my xbox is old(2006 model).. and after using it for about 2hrs it gets too hot(must be about 60C+ inside it), you can use it as a mini radiator to warm your hands up on the plastic its that hot.. I'm good with my hands and I know I can get it(motherboard) in there ok, but would it be worth the effort of will it make things worse. The dvd drive must generate alot of heat and to make things worse its right over the gpu. So I'm thinking the space in the pc case and good positive airflow would be good for it and it may last a few yrs longer.. since people say as long as its kept cool there is no rrod
I was gonna wire it to the pc psu with one of them ebay xbox to atx psu leads, and I will have two 12v 120mm fans (intake and exhaust) fans in the case... as well as the psu 120mm fan. And the case is aluminium which is great for heat disburstion
The guy I bought it off knows his stuff, he did the red light fix on it and x clamp fix and has the back fans reversed and at 12v intaking air and even an extra fan in it at the cpu heatsink, and also has lots of holes on the side/top to let heat out... but it's still too hot after an hr or so, bound to break again like this i think.
Is there even any custom heatsink for the cpu/gpu that will dampen the heat a bit, or any way to screw a 80mm fan to the heatsinks?.. its becoming now that I'm too scared to play it and can't enjoy getting into games with all that heat on my mind and the thought it may break again if I don't do something about it.
Anyone tried this or heard any good/bad points about doing it?.. I dont care what it looks like on the outsides with dvd drive sticking out, as long as its cooler, which it should be by about 50% I'm guessing
..this keeps getting better and better... I'm defo selling this ASAP!.. and going ps3
