speed
  • griff
    • Mar 2009
    • 343
    speed
    i have just had virgin in to up me to the 50meg speed and i do a speed test and it says 46 on average which is fine but when i download on newsleech 3.9 it fluxuates a lot it goes from 3.6m/bits down to 1.19 m/bits any ideas why it fluxuates so much ? it was fine when i was on 10meg it always stayed on 1.19m.bit
    cheers
  • oneman
    • 307
    you know there are throttling periods for usenet and P2P ?
    Check the virginmedia website, can't be bothered to type the times again.
    • griff
      • Mar 2009
      • 343
      i know about the throttling. it isnt that. it would half the connection not make it fluxuate
      • oneman
        • 307
        Actually it will fluxate depending on local. And speed is not half, its up to a 3/4 reduction.
        Have you tried virgins own servers or free trial with giganews or astraweb ?
        • MrFug
          • 880
          If you can, change your SSL port. I know Giga offer 2 SSL ports, 443 and the standard 561 (er, I think). The latter suffers from traffic management, but when using 443 I get my 50mb connection consistently maxed out.
          • griff
            • Mar 2009
            • 343
            i am on astraweb and it has been fine for yrs. i was on 10 and had no probs always maxed out now i am up to 50 its fluxuates a lot
            • oneman
              • 307
              Have you called VM about it ?
              What are downloads via http or FTP like ?
              • MrFug
                • 880
                Since you've been a usenet user for years you probably know this but make sure your connections are set to 20 in your server settings. Having few connections can cause speed fluctuations.
                • griff
                  • Mar 2009
                  • 343
                  done that mr fug. i changed the port number to 443 and work fine now ideal thanks now i can use the full 50 ha
