best way to look after laptop battery
  • wetdog
    • Apr 2011
    • 989
    evenin chaps and chapesses, what is the best way to preserve a laptop battery?
    leave it in thr machine? takeit out the machine? let it go flat and recharge or keep as much charge as much of the time etc
    ta,
    mick.
  • johnboy1974
    • 3418
    Mick i was told by a computer engineer to remove it unless i was using the laptop on battery. Dont keep it charging while switched on and using it.
    • wetdog
      • Apr 2011
      • 989
      cheers dude, any more from anyone else?
      mick.
      • cactikid
        • 12017
        if battery is removed and you lose power as in plug gets pulled out can you not do more damage?maybe just run on battery then power on when low
        • alistairlee
          • Feb 2010
          • 15
          Hi
          Pretty sure the laptop charging circuitry in a newish laptop is smart enough to run from mains when connected and charge only when needed, so would not recommend removing battery ever - if you accidentaly kick the power lead you could cause HDD crashes and lots of other issues. Laptop from a while back may not have been as smart but they have it sussed now.
          Al
          • lolooo1981
            • Feb 2011
            • 471
            When you are at home desolder battery of laptop and use only sector, when you are in displacement disconnect all element you don't use like wireless...etc
            But a little charge is not a bad thing if you are not using for a long time.Don't forget,let a battery never charged kill it.
            Best regards
            Original Kwp2000+ and other...
            No stress for all !
            • lolooo1981
              • Feb 2011
              • 471
              Originally posted by alistairlee
              Hi
              Al
              If you have too fear of this, Ondulator is a best way for prevent any damage on Hdd or other things.
              Best regards
              No stress for all !
              • mgmaestro
                • Aug 2011
                If you have the latest laptop, the battery will look after itself to preserve its lifetime. Older batteries are better if you run them flat and then recharge fully and run flat and recharge fully, etc.
                  Hello mate welcome to Digital Kaos i hope enjoy your stay with us..................
                  • wetdog
                    • Apr 2011
                    • 989
                    thanks for the post dude, its unusual to get a newcomer posting advice early on, especially in their first post.
                    a first post is usually asking for help.
                    hope you stay with us and enjoy all the forum has to offer.
                    mick.
                    • tadasb
                      • Aug 2011
                      • 4
                      Don't keep batteries discharged, it's not good for them ;S
                      • dazza1979
                        • 81
                        I always remove the charger when battery is fully charged - over charging the battery will accelerate the wear level.
                        When using it on just battery it is best to optimize the power saving options for the most battery life.
                        • alistairlee
                          • Feb 2010
                          • 15
                          Hi
                          The circuitry in a newish laptop will stop charging the battery when its full, there is no need to pull mains power, you will shorten the life of your battery by doing this, as the batterys have 300 cycle charge/ discharge life, then the laptop starts running out of battery power quicker, best to leave mains power connected when you can.
                          Regards
                          Al
                          • TheCoder
                            • Jun 2011
                            • 693
                            Its difficult to give a definitve answer as there are so many different battery types in use and even more laptop types with different charging circuitry (even different batches of the same product may have different battery/charger).
                            Generally, if you can run on mains and your laptop supports it then its best to simply disconnect the battery pack. Whether you disconnect the battery in a charged or discharged state really depends on the battery type and the circumstances (whether you expect the mains usage to be short or long term).
                            • dazza1979
                              • 81
                              alistairlee yes some newer laptops do stop the charge when 100% is reached, but others will only do this if you change the software setting.
                              It's probably best to look at the power management software included on many laptops, they usually include hints & tips.
