At the moment I'm using cucusoft avi to vcd dvd mpeg creator pro but I'm starting to get fed up with it as I have to manually select from 10 quality levels to try and get the best quality that fits into 4.7 gb. This is a big problem as it doesn't just go on the length of the film it takes into account number of frames original size of avi sound quality. I have also tried dvd santa this does set the best quality and get it right first time automatically but I quite often have sync problems after conversion and takes the same length of time to convert as the film lasts, so basically what I'm looking for is a program that converts quickly and efficiently like cucusoft but selects the quality automatically like dvd santa. Any suggestions would be much appreciated ta.
What's the best avi to dvd convertor
Tags: None -
I use this, with no complaints
ConvertXtoDVD - AVI to DVD Video Converter to burn on DVD
Will convert and burn for you no issues.sigpic
"Make it idiot proof and someone will make a better idiot." -
This is a great one too Freemake Video Converter - Free software downloads and software reviews - CNET Download.comsigpicComment
I have just tried convertx and it is spot on cheers lads just need to play about with the settings and see if I can find an auto start it'll make life much easier for the bairnsComment
DK is The Most Valuable Site my friend
Don't forget to do it
right place to share each other, not to
Don't do it when you sleep, will make big cost
Thanks reddevil157, for that link,great software,works well for meThis is a great one too Freemake Video Converter - Free software downloads and software reviews - CNET Download.comComment
why burn to dvd ??
Depending on your set up, you can use a PC HD to send to your sat box ( I use a dreambox for this) or just get a movie type box...1GB and copy movies to the HD and then move to the TV and play back this way.... you will save yourself the expense of a buying dvd's and have a great HD back up as well.Technomate-Dreambox-SpiderboxComment
I do stream them from pc to wii wirelesly but I tend to stick them on disk for the bairns watching in the bedroom or if I send them up to my sister and her bairnswhy burn to dvd ??
Depending on your set up, you can use a PC HD to send to your sat box ( I use a dreambox for this) or just get a movie type box...1GB and copy movies to the HD and then move to the TV and play back this way.... you will save yourself the expense of a buying dvd's and have a great HD back up as well.Comment
