Driver install and update.......
    Does anyone have C copy of either DriverBoostPro or DriverDetective that works they can help us out with.Its for ibm thinkpad t43 none of the drivers on the lenovo site are any good it will be much appreciated thanks..................
    Got them all bar one does anyone have the multimedia audio controller for ibm thinkpad t43 thanks in advance...........
      Sorted.............
      The driver i downloaded is a self extracting package not an installer. So you need to go to your device manager, [Control Panel->System->Hardware->Device Manager] Right click on your "Multimedia Audio Controller" with the yellow exclamation mark, and go down to "Update Driver" a Hard Ware Wizard will open, check the box that says "Install from a list or specific location (advanced)" click next. Make sure you check the box that says "Include this location in the search:" and the driver should be located here "C:\DRIVERS\WIN\AUDIO\SMAXWDM\W2K_XP" if you extracted the package per it's default extraction location. Click next and then finish... it should now find the driver and install it..............
      • MrWho
        • 417
        PCI Vendor and Device Lists
        Use this to identify the hardware and pick the driver let me know if you will have any questions.
        Please click >>> THANKS >>> If I helped you.
          Cheers MW all sorted but thanks anyway.............
