Help Me How Connect Dbox To Pc
  • g417gji
    pls can some help me
    i'm in slight problem, i'm trying to connect my pc to dbox
    i'm using flashFXP on vista system, everytime i try to connect my pc to dbox it fails, i'v input the ip (same one showing in dbox,) but still no connect
    can some tell me how or were i'm going wrong,
    will be truly grateful and appreciate all your help
    thanks in advance
  • djsri
    • 6
    Is the dbox on manual or dhcp? can you ping the dbox from your pc?
      Make sure any firewalls are turned off.
      • youngcrow
        • 5
        im suffering from the same problem could anyone give a little more detail please !!!!!!!
        • smoggie
          • 863
          Switch OFF all firewalls and antivirus on your PC
          (and make sure windows XP built in firewall is OFF)
          2. Power on the TV and DBox, but don?t hook it up to your PC yet.
          Using the remote control, press DBOX > SETTINGS > NETWORK
          Take a note of the DBox network settings
          (this is an example only)
          IP-Address 192.168.0.3
          Net Mask 255.255.255.0
          Broadcast 192.168.0.255
          Def Gateway 192.168.0.2
          Name Server 192.168.0.2
          3. On the PC go to START BUTTON > SETTINGS > CONTROL PANEL and open the NETWORK CONNECTIONS
          Right-click the network card (it may say Local Area Connection),
          and select PROPERTIES > CONFIGURE > ADVANCED tab
          Highlight the ?Connection Type? (in the left window),
          and in the right ?Value window there is a drop down menu (it will probably currently say automode)
          Change the Value to 10 full mode then OK
          Again, right-click the same connection, and go back into the PROPERTIES of the network card
          There is a List of items in the first window (you may need to scroll down further)
          Left-click on internet protocol, when it is highlighted, click the PROPERTIES button.
          Select the ?Use the following IP address?
          Enter the settings, as you seen it on your DBox, except the IP address will be one digit less of the last number
          (eg. 192.168.0.3 on DBox, so use 192.168.0.2 on your PC)
          OK these settings.
          Connect the RJ45 cable between PC and DBox (linking them together)
          Run the Flash FXP program
          On one side should be the files on the PC
          On the other side make sure you select ?ftp browser? (the tab is a monitor and folder picture)
          (It may already be selected)
          Click CONNECT (the icon which looks like a lightening bolt)
          Select QUICK CONNECT the three boxes require some information
          SERVER OR URL = (enter the IP address of the DBox)
          USERNAME = root
          PASSWORD = dbox2
          Then click CONNECT
