multiple boot help
  • kevfield
    • Aug 2009
    • 1224
    multiple boot help
    Hi guys , can anyone help me with this i am trying to do? , what i need is some software that will let me boot multiple windows xp systems but always working from c: eg: 4 paritition with xp on all 4 and all classed as c drive but need to select witch one i want to boot from at start up of the pc .
    Thanks in advanced
    kev
  • m9g
    • 704
    I would think you could just create 4 partitions, run the xp install disc and install into each partition, on creation of the other partitions it will tag them with different drive letters but upon booting into them it should call it C: - you will also have access to the other partitions from any of the xp's you install.
    Cant see why this wouldnt work, i dual boot with 7 and xp so would think its the same
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
    • kevfield
      • Aug 2009
      • 1224
      Thanks for the reply so do both xp an 7 on your pc have a c: drive?
      Thanks kev
      • ray156
        • 669
        Thanks kev
        one thing you aint gonna get is multi operating systems saying c/drive,you can partition the drive and put multi on it,but it will come up in my computer as,C.D.E.F.but when you boot up pc.it will give you an option which O/S to boot from.i think you should go here and have a read.
        How to create a multiple-boot system in Windows XP
        • kevfield
          • Aug 2009
          • 1224
          Ok thanks, i can make multi boot with differnt OS that bits easy but i need it as tho it thinks each OS is on its own c: drive , i think some sort of boot manager in DOS or something like that .
          Thanks kev
          • rg66
            • Dec 2011
            • 133
            When you boot into one if them it will show that system as C: drive.
            Always install oldest first as in XP and newest last as in Win7 and linux should be after that if you want that as well.
            If installing Win7 as well, download Easybcd to customize the boot selection screen.
