hi guys, now i know this sounds like a silly question but can someone talk me through backing up windows xp, wot do i need to do this like a disk or something, its just that i have never done this before and i need to get it rite, bought this comp over the weekend and its got no bk up disk so i thought i would do it myself, any help would be great.cheers..chris......
need help windows xp
Tags: None
thers a few ways u can back-up your info
1. make a partition from your c drive then save everything into the new partition this way when u re-write install windows u wont lose any info
2. USB Stick / CD/DVD write save ur info to any other theses devices
3. remove current HDD and replace with new 1 then install windows
this save time on having to save everything or losing anything
with old HDD u can then add it to ur machine after new installation either by the sata if u have a desktop PC or in a USB Caddy if ur using a laptop -
hi m8, some of that info sank in
but realy all i wont to know is how to bk up my os onto a disk, iam runnin windows xp pro if that means anything.cheers.chris..
A LITTLE THANX GOES A LONG WAY
thanx m8, i think iam gettin it now
, but how do u re format.cheers.chris..
have u saved everything? do u have motherbaord disc drivers?
if yes then find ur xp disc and key put it in the computer and restart
before the computer gets to the loading of windows u will have a 'Press any key to boot from disc option'
then let it load up
(if u dont get this option u must go into ur bios and make the cd/dvd rom drive boot before the hdd)
this will then begin to install and will have options which u must choose to continue
i recommend doing a full hard format of ur drive under ntfs (this will take some time when clicked )
after sucessfull format u then will beable to install a fresh copy of xp
can i get ur pc spec so i can see if ur system will work with windows 7
this is a much better windows to be using than xp
quicker faster more reliable drivers
i can hook u up with windows 7 & key let me know if u want this windows insteadComment
Like Cod3wax says: if you do format the drive make sure you have/download a copy of at least your network card/chipset drivers, if you don't have them you may not be able to connect to the internet this happens alot with hp/compaq and other motherboards with onboard lan. the drivers may not be on the install disc.
This is about the backup utility in windows XP: How to use the Backup utility to back up files and folders in Windows XP Home Edition
XP pro has it installed under Progams,Accessories,System Tools, BackupLast edited by R_J; 28 June, 2012, 04:45.Comment
i could be missing something in this thread.
one thing,is the pc second hand or new.
click start-then my computer, then come back and say what you see,
should be something like picture below.......Attached FilesComment
right click my computer properties and u should get thisAttached FilesComment
