Help Streaming ADMC Sports....
  • Scousedave2005
    • Aug 2012
    • 15
    #151
    Originally posted by kevdhoushby
    It will work, I do it myself, but you have too be watching the match through your VPN, then switch it off, no refreshing of page just press play and it will continue, it sometimes takes about 10/15 seconds to start running again, but it will.
    IPTV is another way too do it. That is broadband too a box.
    was thinking getting a cheap one for me m8 pub
    • kevdhoushby
      • Dec 2012
      • 46
      #152
      Someone on here will help you, I have no idea. I googled this too death before I managed to get it running.
      • baldobaldini
        • Oct 2010
        • 46
        #153
        I done a speedtest with the smart DNS running and I was getting double figures download and 30 ping, I also run it with the smart DNS off and letting the full belt of my internet run it.
        Anyway I can up the CPU? I have heard of overclocking but not sure how or if it can be done...
        Overclocking is not recommended on a laptop. First of all the overclock would be limited and then there's the extra heat, not to mention that it won't make a blind bit of difference in all honesty.
        I'd suggest you try logging in from a family or friend's PC that has dedicated graphics hardware acceleration and see if the stuttering stops. If your CPU is at 100% then that is definitely what you should try to eradicate first.
        • jcm19730
          • 14
          #154
          Smart dns does not affect your broadband speed or ping and it will only work on certain sites supported by overplay, all it does it route the inital connection to admc via there server as far as im aware this is only done once with that website.
          It will work slightly differently with sites like foxsoccer2go as they constantly check ip addresses for geoblocking this how ever will not effect the download speed or ping on your home connection as its all done at the end.
          • Scousedave2005
            • Aug 2012
            • 15
            #155
            well im watching liverpool game now and the pic is bad its like the pixelation is not clearing fast enough
            • Scousedave2005
              • Aug 2012
              • 15
              #156
              Tried to upload pic but can not from my iPad
              • kevdhoushby
                • Dec 2012
                • 46
                #157
                It's the same for me. You can make the picture out, but when the camera angle gets changed or there is a fast bit of play the picture is pixelated.
                TBH I turned the match off in the 26th minute, wasn't worth it after that!
                I am having a lot of problems with my Internet ATM, which I have only just realised, so I'm hoping once that is fixed the picture should be ok. I just need a new laptop!
                • Scousedave2005
                  • Aug 2012
                  • 15
                  #158
                  I TRIED IT AT 2 ADRESSES and same we both on bt home hub 3.0
                  • kevdhoushby
                    • Dec 2012
                    • 46
                    #159
                    I got a crystal clear picture on me mams 10mb Fibre with Virgin. I'm starting to think the picture problem maybe linked too BT. As I had it wired up directly into the HomeHub with 55mb running thru it last night and it was a poor picture.
                    • Scousedave2005
                      • Aug 2012
                      • 15
                      #160
                      i was getting ace pic 1st 2/3 weeks now gone bad tried everyting to improve it it would be better if you could pick what stream you wanted eg low-med-high
                      • joshua99
                        • Apr 2011
                        • 78
                        #161
                        Hi, has anyone tried watching through a media player? I was thinking of getting one & trying it but I do not know if you can put the smartdns on them.I've had a look at the "WD media player" & I'm not sure if it will support the smartdns as it says on it's site "DOES NOT SUPPORT PROTECTED PREMIUM CONTENT". Anyone know anything about it? Thanks in advance.
                        "File Formats Not Supported Does not support protected premium content such as movies or music from the iTunes Store, Movielink, Amazon Unbox, and Vongo"
                        • konatist
                          • 392
                          #162
                          Does this site show all 380 epl matches
                          • malaga0034
                            • Sep 2012
                            • 8
                            #163
                            yes it shows every match
                            i watch on my apple tv airplayed from my iPhone and no vpn is needed
                            • konatist
                              • 392
                              #164
                              Did u use a vpn to sign up got the apps already
                              • pee_bee
                                • 10
                                #165
                                Well BT do have a vested interest in streaming premier football - and it will get stronger.
