I'm not sure there is an equivalent. I'm running an AMD A6-3500, so it's not particularly powerful. I was underclocking it though, and now I have it ramped up to 100% as I was getting stutter.
I've read before that Mac's struggle with flash. How does it cope with HD iPlayer?
Help Streaming ADMC Sports....
What equivalent uk flash streams could I play to see if its my 2009 MacBook Pro (2.66ghz dual core, 8gb ram) - actually, it has two graphic cards - will try it with the higher end (warmer, less battery life) and see if that helps...
its still watchable - miles better than the free streams anyway
also, the ipad app displays GMT times by default... Why is this? Have the Egypt vpn switched on?...Leave a comment:
I think it was only the tennis last night. The stream was spiking as high as 1.5Mb/s but have gone back to normal now. I'd wait and see what the streams are like Saturday.Leave a comment:
Seem to get HD ish quality - when Ethernet connected - but frames per sec seems to be all over the place - bit stuttery / missing 2-3 fpsLeave a comment:
Hola also seems to be the equivalent of using a VPN, so the quality is never up to scratch.Leave a comment:
Heard now peeps using hola are having there accounts suspened because of changing ip addys....Leave a comment:
Doesn't really matter. I've googled embassies in the past for a number.Leave a comment:
when you subscribe and you are asked for a mobile tel number, How many digits do you put in (not including the country prefix for egypt +20)? ... or does it not really matter?Leave a comment:
Hola is good and work but my finding is its not stable and best to stick with smartdnsLeave a comment:
Leave a comment:
