2D to 3D Conversion Software
  • Cod3waX
    • 1011
    looking to convert my 2d movies into 3d
    in my case it would be better for me to convert rather than download again + some films haven't been made 3D
    hope someone can help cheers
  • billy2
    • 1381
    would this be any help m8 ????
    2D to 3D 1080P Full HD Video Converter Box - RY-V3D
    there is a software to do it been playing with it a bout 2 mths ago will see can i find it on pc
    • Cod3waX
      • 1011
      looks good but dont plan on spending money other than electric
      prog would be great if ya could find it or tell me whats it called n i go off n find it
      • billy2
        • 1381
        found in m8 its called ImTOO3DMovieConverter if you cant find it let me know and i will upload it
        • Cod3waX
          • 1011
          all installed
          just looking at settings
          what setting do u put ur 3d depth at ?? 1- 10
          • m9g
            • 704
            handy tool, trying it now, not sure about the depth setting either so trying it midway to see what its like, this will give me a mid-range sense of what the setting should be.
            Thanks for the software recommendation
            DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
            • ramblers123
              Just in the process of a new 3d tv can anybody tell me where to get this software from...... thanks.
              • billy2
                • 1381
                right here Google
                • m9g
                  • 704
                  hmmmm not having much luck at the mo, tried converting a film twice from 2d to 3d with a .mkv output and although played back on pc i'm getting SBS pictures but on tv its saying 3d option not available.
                  Anyone had luck with this 2d to 3d conversion if so what settings did you use? and what output format?
                  • Cod3waX
                    • 1011
                    i been using output format mp4, dvix and xvid
                    the display resolution im having trouble with as i dont understand it yet and also dont understand the next option of video size
                    this is a bunch of keys for version 1.1.0.20120720
                    C60A-4E8F-93D7-1B5E-8E12-F911-3843-F309
                    D7E9-0A0B-5C7E-7E95-1C96-B956-7563-5028
                    06C2-8E4C-28E4-A065-B0AF-4672-C2B9-627D
                    24E0-AC6F-1BD7-9356-A06D-6E99-CD14-3177
                    F539-7DBC-A0E4-2866-05F9-A656-FCA8-3E5C
                    • Cod3waX
                      • 1011
                      what ive been doing is letting the conversion run for 2 mins then stopping it and then test the part conversion
                      • m9g
                        • 704
                        So have you had any sort of success with those formats on a 3DTV? i thought 3D films had to be .MKV
                        I'll keep trying different settings, if you could keep me updated with your success settings and i'll do the same for you, I'm sure theres a simple solution to get this working as i'm sure they wouldnt make the software if it didnt work.
                        I've tried finding guides on the ImTOO site but they dont explain settings, they just tell you what to click.
                        • billy2
                          • 1381
                          have a try of this m8
                          [ame=http://www.youtube.com/watch?v=D9dEUnJpANE&feature=related]How to convert common 2D DVD video into 3D videos with DVDFab 2D to 3D Converter - YouTube[/ame]
                          • m9g
                            • 704
                            Ooooo lovely thanks will have a look later
                            • m9g
                              • 704
                              well i tried and yeah it worked sort off ish - created SBS avi file which my TV joined when played through 3D and yeah sort of depth ish but its almost like its pushed the whole 2D image further back in the tv, almost like the tv had depth rather than the image if you get what i mean. I might have to play with the settings and watch it a bit more and perhaps try some other videos - but yeah we're getting there. I do realise it wont be as good as large major companies can produce.
                              COD3WAX - try it, at least it works - ish
