sony vaio bios password problem
  • wahye
    • Aug 2012
    • 125
    I have a sony vaio laptop model PCG-7R2M
    the problem is that it asks me password in bios and I have not the code
    I veus know what type of bios chips for me the program or if there is a calculator which can calculate me onetime password
    thanks in advanced
    the experience is years + years of work !
    don't forget THANKS + REPUTATION
    if my post was helped !
    Not sure if this one has jumper or battery,but either way you have to get to the M/B,if it is the battery option then remove it for half an hour that should reset it.If not you will have to find the correct jumper..............
    • wahye
      • Aug 2012
      • 125
      thinks for reply
      i want know what exactelly a chips of this bios 24c02 or 93c46 i try to read 93c46 but i find ffffffffffffff in dump
      sorry for my bad english
      • wahye
        • Aug 2012
        • 125
        problem solved
        • caveman_nige
          • Feb 2008
          • 4920
          Originally posted by wahye
          problem solved
          its always useful for other members if you explain how you solved your issue as it well help others in the future..
          • wahye
            • Aug 2012
            • 125
            ok i reprog the chips bios in the first adress i write 00000000000000 and the bios back to the states as if it's initial first use for this pc then we can write password for the first time
