Bios upgrade
  • ecufix
    • Feb 2010
    • 2214
    Bios upgrade
    Hi I have a Dell optiplex GX280 that I want to upgrade the bios on . I have the software but the instruction says I must make a ms dos start up disk , my question , is there a way to make a ms dos start CD instead , please help , thanks , regards
    Do what you can with what you have .
    Why do you need to upgrade it m8???
    Coz if it goes wrong your without a pc.................
    • ecufix
      • Feb 2010
      • 2214
      Having problems such as it wont load usb modem and other usb based diag software , the chap I bought it from suggested that because it comes from a big bank it might have been tailor made to their specifications ??
        What operating system m8.........
        • ecufix
          • Feb 2010
          • 2214
          I loaded Xp Pro
            You shouldnt have any problems with xp m8,is it a fresh install ...............
            • ecufix
              • Feb 2010
              • 2214
              Fresh , reformatted the hard drive installed from original cd , the current version of my bios is a few versions older than the one I have just downloaded from dell
                Ok dont know what to suggest realy,never had to make a dos disc to update bios. You select the file restart and it does it,could be you ports have you installed all the drivers....................
                • ecufix
                  • Feb 2010
                  • 2214
                  Me thinks I shall rather not take a chance and mess this up and will rather spend a few quid and get get the local pc repair guy to have a look , thanks for your time mate , regards
                  • fail2ban
                    • 101
                    The point with disc is when using old bios upgrade system from dos, the program creates backup of bios prior flashing new one. You can create usb bootable flash drive with all files and then boot from it and use it instead of floppy disc.
                    I think you can download dell utility for flashing directly from windows on their site, send me service tag and I can check if you want it to.
                      Ok you dont need a dos disc m8 thats only for the 240 and b4 .The bios file you have is executable file exe so you just go through the motions and then a restart when done thats it......................
                      • ecufix
                        • Feb 2010
                        • 2214
                        This is what I found
                        File Format:Non-PackagedDownload File
                        Add to My Download List Go to My Download List
                        File Name:GX280A08.EXE
                        Description:This file format consists of a BIOS executable file. To use it, download the file and copy it to a DOS-bootable diskette. With the diskette in the floppy drive, reboot the system and run the program.Download Type:HTTPFile Size:548KB
                          As i said you only need the DOS-bootable diskette for the 240 and b4 yours is the 280 ...............
                          • fail2ban
                            • 101
                            Are you searching for bios with service tag or by model?
                            • ecufix
                              • Feb 2010
                              • 2214
                              When I run the .exe file under windows an open with window pops up .
