Seagate hard drive clunking
  • Grover2000
    • 104
    Hi can anyone advise if there is a DIY fix for my seagate barracuda ST3500418AS?
    The drive came up with the error CRC and now has clunking.
    I have not powered it since to protect it from further damage.
    I need to recover the data though
    Any help on the matter is greatly appreciated.
    Grover
  • Reapers
    • 242
    tricky issue it could be for a number of reasons why its doing that
    bad sectors (most common with seagate hard drives)
    pcb board issues and needs replacing sometimes
    hard drive on its way out
    where you moving large files across at the time?
    have you tried the seagate diagnostic tools
    (seatools)
    Windows version *tutorial Here http://knowledge.seagate.com/article...S/FAQ/202435en*
    SeaTools for Windows | Seagate
    Bootable version needs to be burned to disc *tutorial here http://knowledge.seagate.com/article...S/FAQ/201271en*
    SeaTools for DOS | Seagate
    Their is also command prompt you can use
    the chkdsk command to scan for errors and if need be
    so to the start type cmd run as admin
    type chkdsk /r C:
    change c with your drive letter
    it may ask you to restart the pc so it can scan it during boot so it can
    unmount the devices needed in order to fix it.
    hope you get it fixed
    • eri1987
      • Feb 2013
      • 21
      If u havent tried yet, it could be maybe useful to try one of the hdd recover softwares, but first it is better to do a repair of the damaged area (surface) with hdd regenerator and then use stellar or recuva to make a copy of the files that u want to extarct.
      Pls let me know
      • Grover2000
        • 104
        Hi can anyone advise what the state if play is with this drive. The drive originally developed a CRC fault and over the space of a day it now just spins for 2-3 seconds and clunks then stops spinning.
        Unfortunately the data on the drive is purely personal photos and means a lot to me, but I can't afford the hefty data recovery bill that Seagate is offering.
        Would you believe the dam this is still in warranty till July and Seagate will happily replace it, but charge for data recovery. (Surely if it is in warranty they should suffer the bill of data recovery?)
        I have tried Seatoolz and it fails.
        Anyway I have purchased a like for like drive to try and salvage myself if possible.
        Any advice on where the fault maybe and what I can do to repair it.
        Just need to salvage the data.
        Any help is greatly appreciated
        Grover
        • mtv1
          The Stig PT
          • 4413
          data recovery software free download filehippo google that mate
          data recovery - Google Search
          good luck also search for tuts on how to on youtube is good
