Windows 8 downgrade to windows 7 ??
  • worcestersauce
    • 136
    Hi all, my lovely wife has had a laptop recently with windows 8 installed on it, and like everyone else (or so it appears) she hates it.
    Was wondering if there is a way to downgrade to windows 7 without any extra cost ????
    I'm sure someone will have the answer, thanks all
  • ajax2061
    • 395
    find out if you can get all the driver in win7 format, if so download a image and windows loader
    • worcestersauce
      • 136
      Thanks Ajax, i have been told there might be a problem with drivers and it sounds a bit technical for tbh, but cheers anyway.
      On lots of websites, the good wife keeps getting a message about shockwave flash plug-in needing to be the newest version but windows 8 wont let her download the newest version for some reason.
      This is the main reason she hates windows 8.......(I'm still on vista so i'm no help )
      So if anyone knows how to get this shockwave flash plug-in working on windows 8, please help me be "hubby of the year" and get this sorted !!
      • ajax2061
        • 395
        a lot of the I see this its just activex filtering turned on.
        Alt F to get menu then tools then untick activex filtering, Your flash player is probaly upto date already (win8 and win7 both use ie10 now)
        • Reapers
          • 242
          is it the way it looks? i understand not everyone likes the metro style but
          Operating Systems always want innovation and try to move forward and
          people either reinstall older windows or make the windows 8 look like theirs
          with themes or customized versions because windows 8 will get the future
          updates and continued support for a longer time frame
          example
          Welcome to Classic Shell
          • worcestersauce
            • 136
            ajax mate, that Alt F only brings up file but you mentioned ie10, she is using firefox so it maybe a different way to get to untick activex filtering which i havent found yet, dont know if you know but any more advice very much appreciated, thank you
            • worcestersauce
              • 136
              Reapers, she has got it looking like the old style windows though i'm not sure which program she is using (didnt cost though) and she is still using windows 8 at the minute its just this update problem thats pi**ing her off, maybe once we have worked out where this activex filtering is, and get it unchecked, it may well be fine. Thanks anyway mate
              • Reapers
                • 242
                maybe this will help?
                • Lodger
                  • Mar 2010
                  • 4
                  How about partitioning your drive and installing win7 with an option of dual boot?
                  • krazylegz
                    • 2834
                    I've just took windows 8 off mine and put good old 7 back on. I hated it with a passion, seemed complicated to do something simple like access control panel, the only thing I liked was how fast it booted up
                    Sent from my iPhone using fingers and thumbs!
                    PS3= krazylegz120282
                    • worcestersauce
                      • 136
                      Thanks again reapers, still not quite there as windows 8 home edition doesnt use group policy and my wife uses firefow not IE 10, but you are on the right wavelength i think. Cheers for the reply again........anything else perhaps ????
                      • ajax2061
                        • 395
                        seams a few ppl getting this error some say to uninstall then reinstall in safe mode, heres where I have been reading cant help too much though as running ie10 stopped using FF years ago when it had memory hole issues
                        http://support.mozilla.org/en-US/questions/960667
                        • Reapers
                          • 242
                          the only real way would be in Firefox is to try disable JavaScript but a lot of sites use JavaScript in their code to work
                          did you try updating adobe shockwave player?
                          Adobe Shockwave Player
                          ajax2061, on them memory leak's its when firefox uses too much ram it was corrected a while back
                          in future patches.their was also there was a manual plug/stopgap for the previous versions
                          when on firefox
                          go to your address bar type about:config
                          right click in the window, choose New, Boolean
                          type in the following text:
                          config.trim_on_minimize set this as true , this will allow firefox to run at lower memory when idle and use less paging file resource
                          • Chadleynet
                            • 30
                            For me, the issue was the new start menu. I hated it, the simplest thing I did was install "Classic Start" from Ninite - Install or Update Multiple Apps at Once . In two clicks, I had the classic Windows start menu back, and was back in action.
                            • Saltire
                              • 1361
                              Just install a hard drive wiping, clearing, formatting programme and scrub the hard drive then install windows 7 (version of your choice), simple as that, make sure to delete the extra part of the partition that that serves as a backup section too, its just a tiny part of the hard drive but it will be mentioned in drive management or in the scrubbing tool you use, scrub the lot mate and then install your windows 7, easy peasy !
                              p.s
                              just realised this thread is now several weeks old, ohh well, maybe this will help someone else doing same thing, and this info gives me even more info myself to avoid windows 8 for a while yet "unless I can get it to act and look exactly like windows 7", can I ?, let me know anyone please ???
                              I havent looked into it much as the early reviews of windows 8 were enough to put me right off it.......Cheers.
