hi , turn on laptop and all I get is blue screen saying windows had to close down to stop computer been damaged , have tried safe mode , have no back up discs anyone any ideas cheers
blue screen
Tags: None
did it come with windows installed have you any disk ie xp or vista -
The problem is caused by bad memroy chip or harddrive boot sector corruption. All information on your harddrive is still intack if you are running IDE or simple SATA connection and formats in FAT/MTFS so becareful as to not corrupt it. Depending on which is more important the files on your harddrive or starting the system you need to start changing hardware to find out just what problem you have that is keeping windows from starting..Comment
The error code is documented here: Windows?2000 Stop Messages
You might want to try downloading a linux live cd/dvd such as knoppix. You could use this to recover the data, to test the memory (type memtest at startup), and hopefully to fix the problem.
A guide for recovery using knoppix can be found here:
Computer First Aid Using Knoppix
A dvd version of Knoppix can be downloaded from here:
and needs to be burned onto dvd (e.g. with Image Burn)
If there is nothing important on the disk you can reinstall windows but will need to obtain disks to do this, (you can try ringing the manufacturer and asking for recovery disks.)
Guides for reinstalling windows here and here:
How to Reinstall Windows Without Losing Your Data
Step-By-Step: Reinstall Windows - PC World
Hope this helps
when i run KNOPPIX it goes so far ,last 2 lines read: error: cannot unite read only media and inital ramdisk, read only dvd system successfully merged with read-write/ramdisk, init: line1013: cannot create/var/run/utmp:nonexistant directory kernel panic -not syncing: attempted to kill init , what the f"""k does that mean
