Help clone PC "ID"
  • ruffles1986
    • Sep 2011
    • 1283
    Help clone PC "ID"
    Hello, i need your help. I have a partition damage and i lost some information of them.
    then i want to format this hard disk, but i have much softwares activated (i have saves activation codes), i want reinstall all softwares with old activation codes, but for them i need clone the PC "ID hardware"
    How can i do it for use the old activation codes? How does i clone the "hardware id"?
    Very thanks in advance!
    P.D. I already have a buckup of my partition but at 95% throug error and the Operating system is unestable.
  • Cod3waX
    • 1011
    u need to make hidden files and folders visible - Open up any folder then click Organize/folder and search options/view/show hidden files, folders or drives
    next
    most of ur saved software logs are stored in the appdata folder hidden on the C:\ drive - C:\users\YOU\appdata
    In here u will find 3 folders Local, Locallow and Roaming
    These folders contain the saved keys to your software
    The best way to make this work for you is to install the software on the new install then simply find the keylog files by viewing hidden files thru appdata and replaceing that file with the old one Effectilvly patching the program
    hope this works
    The only way this might not work is if the new installed windows is called something different from the last windows u used but if ur using windows 7 u can correct this (name of computer, name of user)
    • ruffles1986
      • Sep 2011
      • 1283
      I use Windows XP can do it in thi OS?
      Anyway i remember read on the web that is possible change (or clone) "the ID hardware" of PC to do work old activated softwares with old activation keys
      Anyone know this solution?
      • Cod3waX
        • 1011
        yes it should work on xp because all ur doing is updating the log file of the program
        but like i said ur new windows will have to be called exactly the same as the old window to insure a clean update of the program u will patch
        down side of this is that in XP u cannot change the name or computer ID unless u do a clean install
