Looking for
  • lplate
    • Apr 2014
    • 5
    Looking for
    hi people I'm looking for a copy of Windows CE 5 OS I'm trying to get an old PDA up and running but it needs CE 5 to do the job I'm wonting it to do so can anyone help please
    AWESOME dude.
    welcome to dk the worlds best website.
    this is against dk rules mentioning torrents, but I got win ce couple years ago from torrent but wanet brave enough to put in working of.
    let us know how you get on
    • Squadr33
      • Aug 2013
      • 129
      i have Windows CE 5 original iso if you want
      here you go: http://www7.zippyshare.com/v/85716784/file.html
      " You can’t be a true petrolhead until you’ve owned an Alfa Romeo " - Jeremy Clarkson
        How do you load on to PDA mate? Interesting subject
        • Squadr33
          • Aug 2013
          • 129
          In the case with my iso ..just mount the iso or burn it.
          Check the pda/pocket pc makers site for the bootloader for your device if needed/
          connect the pda/pocket pc with your pc with activesync or windows mobile device center.
          open the setup file and start the wizzard, accept the terms...
          Select "Custom (Tools and OS)" within the "Setup Type" window.
          Change the folder where Windows CE 5.0 will be installed by clicking "Next"
          and then select "Change" within the "Destination Folders" box. Click "Next."
          Select the microprocessors you wish to support in the "Custom Setup" box and then select "Shared Source for Windows CE."
          Select "This Feature Will be Installed on the Local Hard Drive" and click "Next."
          now start the installation and...Voila!
          the way you install windows ce varies between different windows ce versions & pda/pocket pc manufacturer
          some need bootloader to accept installation of windows ce, some can be installed easily using usb/serial cable and sync..
          • lplate
            • Apr 2014
            • 5
            Thank you Meat-Head & a big thanks to you Squadr33 I'll let you know how I get on, my pda is an old hp h5550 2003 one, it as CE4 on it atthe moment
            • Squadr33
              • Aug 2013
              • 129
              No problem, let me know if you got any problems or questions..btw your hp originally runs on windows mobile 2003...why is there CE4 on it now...
              if you want to try getting windows mobile 2003 back on it let me know
              cheers
              • Squadr33
                • Aug 2013
                • 129
                And found the link for your device drivers, firmware etc...
                HP Ipaq h5550 support:
                Hope this helps a bit more , will update with official firmware when uploaded
                cheers!
                • Squadr33
                  • Aug 2013
                  • 129
                  Sorry yet another reply...
                  Official HP ipaq h5550 pocket pc flash-able firmware. (uploaded it to zippyshare for you)
                  just extract the archive and run the executable, this wil unpack all files needed for flashing the original updated firmware to your ipaq
                  • lplate
                    • Apr 2014
                    • 5
                    """""""""""""" Sorry yet another reply..."""""""""""""""""""
                    hay you can reply as many time as you want bring gifs like this mate wowhoo
                    do you any more flash-able firmware like ce5 save me righting a .gz files
                    its new many years since a played with embedded things I now I have a fare bit of software but its
                    across several computers and drives but its finding it thanks again mate
                    • Squadr33
                      • Aug 2013
                      • 129
                      ill have a look what i have and will let you know ..just glad to help ghehe
                      • Squadr33
                        • Aug 2013
                        • 129
                        Had any luck so far? Let me know if your hp is working now...
                        Verstuurd vanaf mijn ME172V met Tapatalk
                        • lplate
                          • Apr 2014
                          • 5
                          sorry sqadr33 I've been working silly hours having to getup for 03.00 in-bed 8pm my Hp is working fine thank you m8 I'm trying to get it doing things it was never meant to do but no time at the moment I will keep you updated when I can get back into it
                          • Squadr33
                            • Aug 2013
                            • 129
                            Good to hear, let me know what you want it to do..I have mcse so i might be able to help
