Install xp to another partition problem
  • kospoz
    • 1274
    Hello i tried to install winxp to a new partition but i had problem.Master system i have win7 and i want to put and the xp in another partition.Someone told me that i must have first xp and then win7.Is there any solution?
  • Batman1310
    • Feb 2014
    You need to install Xp first onto a new (either virgin or formatted) hard drive, then install win 7. The win 7 install will create a new partition and also create a boot option on the bios post startup screen.
    Remember xp is no longer supported, only xp embedded is getting security updates.
    An easier solution is to install a VMware program in win 7 and install xp into the vm.
    hth a little, Dave.
    • Diagnos
      • Mar 2015
      • 22
      Hi. The best solution, and I would say the easiest, is to install BootIt Bare Metal from TeraByte. Then you can have any mix of OS's you like, and multiple copies of each. It is a fantastic program and easy to use. Indispensable if you constantly test and install new software. I would rate it utility of the decade myself.
      Kind regards Dx.
      • ferretuk
        • 48
        VMWare does the same job and is good for testing
