Help with Newsgroup Downloads please !
  • acestu
    • 269
    Hi, I have read chims tutorial on newsgroups and i think i am doing everything right, unfortunately my first download is taking about 22 hours for 1 backup, i have subscibed to Astraweb and also got a vip account with nzbmatrix, i searched for my nzb and downloaded it opened it up in grabbit and there were about 150 jobs in the que the download speed is about 225 kbs and it is taking hours which cant be right coz i can download a movie in about 7 hours with a torrent file, could somebody please give me some advice please
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • Chimaera
    • Jun 2009
    • 242
    if your normal speeds are far more than with newsgroups it sounds like a limiter or a setting thats different
    for me i use a free news server from virgin and it maxes my connection within seconds of starting the nzb
    there isnt too much to set in grabbit, thats why i use it in the tutorial
    Do you have a router that you havent opened up a hole through ?
    http://www.simple-software.co.uk/
    • acestu
      • 269
      thanks for reply
      Hi Chim, i am with virgin media, and using a belkin router but i havent altered anything on it, do i need to do some port forwarding or mess with firewalls do you think
      Acestu
      • dell_xps
        • 2558
        What size of files are you downloading m8 ? 50MB ?
        How many seeds do you have downloading at once ?, in grabit you can download more than 20 odd at once.
        Are you running a torrent prog as well? if so close it down as someone is uploading from you causing your download speed to be slow.
        HTH
        • Spacerat
          • 53
          Are you trying to download at certain times of day? VM "shape the traffic profile" i.e. cut down the bandwidth after a certain amount of data has been downloaded (think it is between 10:00 and 15:00 and again between 16:00 and 21:00).
          The quantity of data you can download before you are capped is dependant on the speed of your connection, as is the speed they limit you to.
          More info here - Virgin Media Broadband:Traffic management - & Traffic management
          (Moderators - not sure if I'm allowed to link to an external site like this. If I'm not, please accept my apologies and I will remove.)
          Cheers,
          Spacerat
          • leefaster
            • Sep 2009
            • 10
            Hi read through the guild to newsgroups and seams ok and easy to follow, I have been using newsgroups for a number of years now, these are the progs use (may be of help). For the newsreader I use newsbin pro (find it here NewsBin NNTP Usenet Binary Newsgroup Robot) the latest version includes quick par and a search it also groups the files together in the search list. You can search with nzb files or just key words. It also puts the files back together for you as well leaving just the iso or img etc. to burn. You can trial the program for 10days.
            AS for newsservers I use newsdemon (USENET Newsgroups - Uncensored Newsgroups and USENET access from Newsdemon.com) this is a pay server but retains for 400 days and allows 20 connections at the same time.
            Using these two I max out my VM connection every time.
            • acestu
              • 269
              Hi Guys, sorry just reloaded pc after a hard drive crash, reloaded everything now and when i use grabbit the download speeds are going from 0 to about 453 kbs every 6 seconds so i think its my slow virgin media connection, is a 1 meg connection no good then / , and if so what sort of speed do you need ?.
              Acestu
              • Spacerat
                • 53
                I've got a 20Mb link on the XL package, and can pretty much max that out on Newsbin and VM news servers.
                • buckoff
                  • 13
                  I'v got a 24Meg connection with BeThere, getting about 14Meg download on the newsgroups with Powerusenet and 6 connections, using Newsbin Pro, never had a bit of trouble
                  • martin-f
                    • 535
                    i am on 50 meg and i get this plus i use astra web and grabbit
