Redundant router
  • xant14
    • 2062
    Redundant router
    Hi
    I have a Buffalo AirStation WHR-HP-G54 Wireless DSL Router/Access Point with 4 port switch - High Power
    I used to have it attached to my Virgin cable modem. Now with a new modem/router.
    Can this be used elsewhere in the house inputted with a ethernet cable from new modem to make a 4 port thingy?
    And will the aerial boost wi-fi signals?
    Or should I FIITC.
    Rob
  • cunny
    • 4915
    Yes it can be used elsewhere. Just setup as a ap (access point)
    If you want 'seemless roaming' have ssid and all security matching main networks.
    Personally I have 3 routers acting as access points in various locations and different radios. Works well instead of repeaters
    • xant14
      • 2062
      Cheers Cunny. Don't know half of what you said, but inspired me to have a go.
      All the best bud.
      • cunny
        • 4915
        Forgot to mention that have main router handle all dhcp requests and turn off in second router otherwise you could end up with ip conflicts
        • Inovator
          • Mar 2010
          • 65
          And add sequential IP's to secondary router such as 192.168.1.2, 192.168.1.3 (192.168.1.1. is probably your main router).....adjust pool range in DHCP of main router outside these adresses e.g.:192.168.1.100-.192.168.1.240.
