help with my vpc!!!!!!!!!!!
  • the dogy
    • 8
    hi guys im goona try to explain my problem,the thing is ,ill install on my pc virtual pc,and ill install into a mechanic program,this is about 9 dvd,the thing is i need to be changing the imagen(iso) in the virtual pc every time to try to looking for a diferent car or information,like if you will change the dvd on your real pc.there are some way to put all tha dvd or imagen iso all together to dont change the imagen all the time,or its no posible? any way ill wait for some answer and thx in advance,good luck!
    im sorry for my english
  • manxspud
    • 1768
    hi 8... you could try to load power iso in to your virtual pc and then make a virtual drive for each disc iso you need... you will still need to swap between iso img but at least all will be loaded and ready to use...each iso would loaded in a separate drive and you could have in theory as many open as you needed.
    there was a link to power iso on here some where i will post it back here if i come across it... best of luck @manx
    • manxspud
      • 1768
      here we go...
      RapidShare: 1-CLICK Web hosting - Easy Filehosting
      hope it helps...
      • cunny
        • 4915
        If i am reading this right? why not just create images of each disc with imgburn, then use daemon tools to mount the images?
        You can set the amount of virual drives in daemon tools easily.
        • the dogy
          • 8
          thx for ur answers pals,ok lets see.i already got the isos for each dvd. but the thing is i cant change the information cuz the program ask me for other dvd , what i mean is ,if i am
          waching info.of dvd 2,and need to see info of dvd 4.i need to change the imagen,disable no.2 and mount no.4 ,and now i can watch my info.and like this all the time.
          u dont know if i can make a single iso to all isos with all info into, and if is posible how can i do this .
          thx and good luck friends!!!
          • manxspud
            • 1768
            hi m8... OK i understand what you are asking... if it is possible i do not know of away.
            • cunny
              • 4915
              So basically say you got dvd 1 mounted. U will need info off say dvd 6? Will look into a way now
              • the dogy
                • 8
                thx.guys sorry dont anwer early,
                yes i got dvd no.1 mounted in the virtual pc but the program have 18 dvds so every time i need to looking for some info diferent ill need to mount other imagen dvd 6,7,3,5,8,9,.yu dont know if there are some way to put all the imagen together in a single imagen.
                thx. in advance. i realy apreciate ur help!
                • cunny
                  • 4915
                  I know dameon tools only allows 4 virtual drives, not sure on any of the others. So basically you could only have 1-4 mounted.
