file to big to fit on dvd, useing dvd fab - help please im pulling my hair out ...
  • thegunners
    • 83
    ok i used dvd fab to copy the dvd [as shrink wouldnt do it ] it copys it ok and leaves vob files but its to big to fit on a standard dvd ?? i even ran the vobs through shrink but it will not shrink it enough .
    how can i copy this dvd and make it fit on a standard dvd keeping all the dvd menus etc.
    thanx
  • opsmonkey
    • 5379
    simple you cant.. your probably trying to copy all the information from a dual layered disc to a single layered disc.. bin the menus and special features and you should be able to get the main film on a single disc
    • billy2
      • 1381
      try 1 click dvd dvd copy5
      • dasteph
        • 1293
        thanx
        dvd2one will shrink the file to fit a disc including extras or movie only without any loss in quality but it is paid for software.
        Impressive little tool that shrinks all your DVD-9 movies into a single DVD-R (or DVD-RW/DVD+R/DVD+RW) with an amazing speed. Extremely simple to use.
        • stonedagain
          • Aug 2009
          • 53
          thanx
          Use DVD Shrink. Open the DVD, Select the "re-author" tab, then drag the "main movie" from the right-hand pane across to the left-hand pane.
