help with restoring my laptop to when i bought it
  • evelyn2008
    • Aug 2009
    • 251
    hi my lap top has gone really slow due to how much cr.p is on it i want to to take it back to when i bought it and first turned it on . i have'nt done a back up dvd yet but i will do but were do i go from there were do i go to do a factory reset and is there anything alse i need to know
    i wiil put all my useful stuff on a usb pen
  • kenmonu
    • 153
    laptop
    what operating systems it running and do your have the cd.
    • evelyn2008
      • Aug 2009
      • 251
      hi its a dell inspiron and it is vista .cd must be in the box would i be able to do it if i can not find the dell cd . wiil have a look now
        Sometimes you get a recovery cd but mostly on Laptops the recovery is a partition set aside on the hard drive. When you start up your laptop press F11 and the option to reinstall to factory settings should be there.Just follow onscreen instructions.
        • kenmonu
          • 153
          laptop
          if its vista then will probably have a partition. follow bulldogs instructions and come back if you need any help.
          • evelyn2008
            • Aug 2009
            • 251
            will do let you know how i get on
            • evelyn2008
              • Aug 2009
              • 251
              had a look every where to try and factory reset my dell but still no luck tryed f12 f11 f3 but i don,t honestly know were i'm looking . does any body have a dell inspiron lap top that has done a factory reset that could help me go through it .
              • dasteph
                • 1293
                you can access your Dell’s recovery partition by pressing Ctrl+F11 when the machine is first turned on. The appropriate time to do this is almost immediately after the power button is pressed. A small message is usually displayed that offers to let you enter the BIOS (usually F2 on newer Dells) or go to the boot menu (F8 or F10, I think; it displays the appropriate key to press).
